Very new to GIS, my map does not align with basemap world imagery
4512
11
08-03-2017 02:43 PM
BujarRexhepi
So i found the attached map online of Kosovo and i was trying to align it to the world imagery, ie similar to how state of Indiana aligns in its "right place" below:
I have no idea what edits i should make to the shapefile to make it fit like this.
JayantaPoddar
MVP Esteemed Contributor
It seems the correct projection to be used is ETRS_1989_Kosovo_Grid.
Right-click the shapefile in ArcCatalog > Properties. Click on "XY Coordinate System Tab". Select the following Coordinate Syatem. (Projected Coordinate Systems > National Grids > Europe > ETRS 1989 Kosovo Grid). Click OK.
Add the shapefile to a blank ArcMap session. Add the desired BaseMap to ArcMap.
Think Location
JayantaPoddar
You need to attach all the files with the same name (not just the .shp file). You will see multiple files like the image below.
Could you zip all the components of the shapefile , and attach the zipped file again.
Think Location
BujarRexhepi
I just did that. See "Kosovo_.zip" in the original thread. Thanks!
JohannesBierer
Occasional Contributor III
I would try to use the shapes or file geodatabase from this page:
Download | Global Administrative Areas
They have Kosovo as well. Maybe they are accurate enought for you - as I can remember the coordinate system is WGS 84
JayantaPoddar
Think Location
BujarRexhepi
It works! You are a life saver, Jayanta!
DanPatterson_Retired
If you are missing a *.prj file, that could be the problem, since it is needed to project the file from one coordinate system to another.
The prj file
PROJCS["NAD83 / UTM zone 16N"
is for UTM zone 16
which isn't in Kosovo by any stretch of the imagination
JayantaPoddar
You are right Dan. The coordinate system should be ETRS_1989_Kosovo_Grid, for the given values of XY extent.
Think Location
Jayanta, I suspect an old *prj was repurposed by just changing the name of the prj
