Conditional Import Statements for Rules
1143
08-12-2017 12:53 PM
DavidWasserman
Occasional Contributor III
Hi All,
I have a hypothetical question about importing outside rules. Is it possible to set up conditional imports? I know in python it is very easy to do something like this:
  try:
            import pandas as pd
 except:
            # Pandas is shipped with ArcGIS Pro and ArcGIS 10.4 and higher.  The previous logic should hopefully prevent users from ever hitting this error.
            arcpy.AddError("This BetterBusBuffers tool requires the python library pandas, but the tool was unable to import the library.")
I was curious if something similar is possible in CGA. In my earliest attempts, I start with a simple import statement:
import Street_Text : "Street_Text.cga"‍
Then, I figured, because the text for import is just text, I can just replace it with a const.
const conditional_text_import= case fileExists("Street_Text.cga"): "Street_Text.cga" else:  "/ESRI.lib/rules/General/Text.cga"
‍import Street_Text : conditional_text_import‍‍
This however returns an error. I have since tried doing the import statements within rules and other variations (I did not think they would work but I thought I would try). Is this simply not possible in CityEngine? Any alternatives?
My goal is to essentially make a rule not being in the folder not be catastrophic to the rules function. It is a small thing, and there are other options, but I just want to keep a rules user experience a little easier. I think I am especially concerned when the functionality being added is not critical to many people's use cases.
Relevant docs:
import
Using CE 2017. Any thoughts appreciated.
CWilkins-esristaff to your knowledge is this possible?
David Wasserman, AICP
by Anonymous User
Not applicable
Unless something changed in CE 2017 that I'm not aware of, conditional imports are not possible in CGA.
by Anonymous User
Not applicable
DavidWasserman
Thanks! I just wanted to check from a Jedi master if I was missing something.
