Require administrative approval for new accounts in Portal?
2229
21
08-15-2017 02:22 PM
CassandraFollett
New Contributor III
Just setting up Portal... seems anyone that hits "Register" gets assigned a new account instantly. How do I require that a registration request be approved by an administrator role?
RandallWilliams
CassandraFollett
New Contributor III
Strangely, this isn't working. I can try and add this property, but then after a minute or so the page refreshes and the property is not set.
RandallWilliams
Hmm, are the curly braces set correctly?
{"disableSignup": "true"}
CassandraFollett
New Contributor III
Yep, and typed in rather than copy pasted (to prevent extra characters being pasted in). Still doesn't work, curious.
RandallWilliams
Strange. I'm on 10.5.1 on Linux, works for me, the 'create an account' button is gone. Which version are you working with?
signIndisableSignup
CassandraFollett
New Contributor III
Also working on 10.5.1 on Linux. Hmm, do you think changing this through the web adaptor rather than on the server makes any difference? I accessed the admin page through the web adaptor to make these changes.
RandallWilliams
I doubt it - I also went though my web adaptor (on Tomcat, installed on the same box as my Portal). Is there anything notable in the portal logs?
CassandraFollett
New Contributor III
Nothing notable. Also using Tomcat.
I do get, "The web server was found to be stopped. Restarting it" which coincides with my attempts to update properties. Maybe there is issue where it knows it has to restart Portal to apply changes, but it is reloading an old configuration as it does so for some reason?
RandallWilliams
Which version Tomcat are you working with?
