Web App Builder (Portal) Print Widget file output path
555
08-16-2017 06:38 AM
JeffPace
I am having trouble with the Print widget in web app builder (Portal 10.5.1).  I have tried both the default print service, and custom print services.
Task: Export Web Map Task
My portal runs on https only, and the print service is configured with https.
However the output file
Has a path of, for example,
www.mymanatee.org/arcgis02/rest/directories/arcgisoutput/Utilities/PrintingTools_GPServer/_ags_1c5aa...
Notice the lack of protocol, and it resolving to http:
Is there anyway to force the output path to be https?
dlaw-esristaff
JeffPace
So just as an update, this was due to a load balancer pointing to http on the web adapter.  If http is anywhere in the chain, it returns http
Making the path https from proxy-load balancer-web adapter-AGS solved the issue
