pulse animation in marker same like current location
1808
08-16-2017 03:50 AM
chiragshah4
I need to implement pulse animation which is currently display in current location of esrimap. I need to show this animation in marker. Is there any way to do it?
MarkDostal
Thank you for your question!  Creating a pulsing marker similar to the "current location" marker is pretty similar to the method outlined here:  Make a pulse animation in AGSPictureGraphics
You would create a symbol using a picture marker symbol which is a blue circle, then set up a timer to vary the size.  Here's an example using a two simple marker symbol combined into an `AGSCompositeSymbol`; the size of the blue circle is changed when the timer fires:
A rough outline of the code:
    var symbolToPulse:AGSSimpleMarkerSymbol!
            symbolToPulse = AGSSimpleMarkerSymbol(style: .circle, color: .blue, size: 18.0)
            let sms2 = AGSSimpleMarkerSymbol(style: .circle, color: .red, size: 12.0)
            let compositeSym = AGSCompositeSymbol(symbols: [symbolToPulse, sms2])
            pulser = AGSGraphic(geometry: mapPoint, symbol: compositeSym, attributes: nil)
            timer = Timer.scheduledTimer(timeInterval: 0.1,
                                         target:self,
                                         selector: #selector(updateSize),
                                         userInfo: nil,
                                         repeats: true)
    let startSize: CGFloat = 18.0
    let endsize: CGFloat = 36.0
    func updateSize() {
        var size = symbolToPulse.size + 1.0
        if size > endsize {
            size = startSize
        symbolToPulse.size = size
Hope that helps!
