Identify layers with large tolerance
1074
08-17-2017 06:12 AM
MarcWouters
New Contributor III
I would like to execute a 'find' command searching for features around the mouse click with a search radius of 200 pixels.
Using identifyLayers and setting tolerance to 200, I get no results. Apparently the maximum tolerance is only 100.
Any ideas how I can increase the search area ?
Thanks for any idea.
Marc
LukeSmallwood
Hi Marc,
If you are searching for features you may be able to use the queryFeatures method FeatureTable Class | ArcGIS for Developers for each of the layers.
This method accepts a QueryParameters Class | ArcGIS for Developers  which allows you to set a geometry to query. So, your workflow would be something like:
1 - get the position at which the user clicked
2 - use the buffer method of GeometryEngine Class | ArcGIS for Developers to define your search area
3 - pass the Polygon returned by the buffer operation to a QueryParameters
4 - pass the QueryParameters to start a queryFeatures task for each layer you are interested in
One issue with that approach is that the buffer will be constructed using an absolute distance rather than a number of pixels. If that's an issue you would need to find some way of mapping 200 pixels to a distance for the current map scale etc. You could do something like:
1 - take the users point in screen-space
2 - shift it by 200 along the x-axis
3 - get the map location of that point
4 - then use distance method on GeometryEngine Class | ArcGIS for Developers to work out the distance between the 2 points (this is what the buffer radius should be).
I hope that helps - please let me know how you get on.
Luke
LukeSmallwood
Hi Marc,
Luke
MarcWouters
New Contributor III
Hi Luke,
Thanks for the suggestion !
I wasn't yet aware that you could also use a geometry in the queryFeatures method.
Using the absolute distance instead of pixels is not a real problem, the only problem we have is using the correct SpatialReference: we create a default map before loading our feature tables, therefor the spatial references don't always match.
We already convert the position of the mouseclick using GeometryEngine::project(), but now I get more results than I expect. The search area is much wider than the buffer (which I showed on the map for confirmation).
Some extra digging into Spatial references is needed, I guess.
