How to create a rule with a with .obj model(with textures) inside
470
08-17-2017 02:51 AM
SerikRahimzhanovsss
im have 3dmodel(obj) how i can create a rule with this model like paris cga and courtyard.cga
CherylLau
You can use the i() operation to insert obj files.
i Operation
In the Paris example, the code extrudes a footprint to the building's height, then it splits it into facades and floors and puts textures on each floor.  In this example, there is no obj file for the entire building.
To create a courtyard, you can use setback() to split a lot into a courtyard and building footprint.  Then, insert the obj on the building footprint using i().  To get different shapes for the courtyard, you can also use other operations (or a combination of them) like split, splitArea, offset, setback, shapeL, shapeU, shapO, and innerRectangle.
setback Operation
