Customize story maps in ArcGIS Online Assistant?
1056
08-20-2017 10:28 AM
AlexP_
Occasional Contributor III
Is it possible to customize source codes in story maps in ArcGIS Online Assistant JSON editing or is it must thru own hosted app? Please advise. Thank you!
OwenGeo
Esri Notable Contributor
Hi Alexis -- No you cannot edit the source code of an application through ArcGIS Online Assistant, you can only edit the story configuration. See this article for more information.
Owen Evans
OwenGeo
Owen Evans
AlexP_
If I want to customize story app such as add features in source code to index html story map, is this the only way to this link below and cannot use ArcGIS Online Assistant? https://developerscorner.storymaps.arcgis.com/an-introduction-to-hosting-your-own-story-map-e2450181...
OwenGeo
Yes, that's correct.
Owen Evans
