Chart widget - Enlarge popup window change size
1401
7
08-21-2017 02:01 AM
MayurDodiya
How to change size of chart widget enlarge popup window ?
Tags (1)
RobertScheitlin__GISP
Mayur,
   In the Chart widgets Widget.js file find this function and adjust the width and height:
      _createBigPreview: function(){
        if(!this.previewArgs){
          return;
        //60 75
        var windowWidth = document.body.clientWidth;
        var windowHeight = document.body.clientHeight;
        var margin = 20;
        var width = windowWidth - 2 * margin;
        var height = windowHeight - 2 * margin;
        if(width < 100 || height < 100){
          return;
Mayur,
   I am a little confused you say enlarge the chart widgets popup window. Do you mean the widgets panel that the chart is in? A popup in the WAB would means the window that appears when you click on a feature that has popups configured in the map.
MayurDodiya
Hi Robert,
Thanks for reply and sorry for the confusion.
We have the two option in chart panel 1. settings & 2. Enlarge window
When you click on enlarge button (zoomin icon), it enlarge the window in bigger size and display the chart in it, I want to change the size of that enlarge window.
Many thanks Robert
Mayur,
          return;
        //60 75
        var margin = 20;
          return;
MayurDodiya
Hi Robert,
I changed the height and width. Many thanks
AP3
Mayur SinhRobert Scheitlin, GISP‌ Guys, can you please help me with the path for Widget.JS file here? I have tried below shown paths but in vain. And do we need to restart the ArcGIS server?
Secondly, is there a way we can change the Chart Size as well not just the Pop Up Window size?
Paths:
C:\Program Files\ArcGIS\Portal\apps\webappviewer\widgets\Chart
C:\Program Files\ArcGIS\Portal\framework\template\filetokens\apps\webappbuilder\stemapp\widgets\Chart
C:\Program Files\ArcGIS\Portal\framework\template\filetokens\apps\webappviewer\widgets\Chart
C:\Program Files\ArcGIS\Portal\apps\webappbuilder\stemapp\widgets\Chart
Appreciate any inputs. TIA!
A P,
  Sorry I do not use on premise Portal so I am not sure of the exact path.
MayurDodiya
I created app using WAB, download app and changed in the function Chart widgets Widget.js file.
