Azure issues with Arcgis Portal and Arcgis Server 10.5
841
08-21-2017 03:48 AM
TonyJoseph
Hi everyone ... hope someone can guide me ... really don't know what else to do.
I've installed and configured ArcGIS Portal + Web Adaptor + ArcGIS Server (all 10.5) on Azure cloud servers (after many painful steps with web adaptor). When trying to publish map services from ArcGIS Desktop and ArcGIS Pro into ArcGIS Portal ... I got errors. After that everything went bad.
  • Issue 1 - Cannot remove Federated ArcGIS Servers in Portal Admin -
    Failed to unfederate server 'xxx'. java.net.ConnectException: Connection timed out: connect
  • Issue 2 - Based on some forum users ... tried to run UnRegister Server unsuccesfully with https://machine name.domain/portal/sharing/rest/portals/self
    HTTP ERROR 500
    Internal Server Error
  • Issue 3 – After step 1 & 2 ... now Edit Settings greyed out in ArcGIS Portal
Please see attachments.
I wonder if there is a script or internal database I can cleanup / reset all these settings.
Thanks so much.
EllenNodwell_IntegraShare
Hey Tony,  It's Ellen.  We are having issues with this.  Had any luck yet?  I will check up with you on this.
