Moving selected features
1838
13
08-22-2017 12:49 PM
BrianBulla
Occasional Contributor III
i'm having some trouble trying to figure out how to move a bunch of selected features from a specific point layer in the map.  This is what I have so far:
//****Get all of the selected ObjectIDs from the VLS layer.
var abLayer = MapView.Active.Map.FindLayers("GISWRKS1.WORKS.AsBuilts").First() as BasicFeatureLayer;
var selection = abLayer.GetSelection();
IReadOnlyList<long> selectedOIDs = selection.GetObjectIDs(); //save the selected OBJECTIDs to a list.
var insp = new ArcGIS.Desktop.Editing.Attributes.Inspector(); //create the Inspector
var moveFeature = new EditOperation();
moveFeature.Name = "Move AsBuilts";
//Loop through each selected OBJECTID
foreach (var oid in selectedOIDs)
insp.Load(abLayer, oid);
moveFeature.Move(..............);      //****  This is where I get stuck....I don't know what to do
I think my approach is all wrong, but I'm not sure what to do.  I'm not exactly sure how to interpret this:  ArcGIS Pro 2.0 API Reference Guide
UmaHarano
Hi Brian,
This snippet below worked for me.  The Move method has a couple of overrides you can use. Move method from Pro API Reference guide
 QueuedTask.Run(() =>
                //Get all of the selected ObjectIDs from the layer.
                var abLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault();
                // set up a dictionary to store the layer and the object IDs of the selected features
                var selectionDictionary = new Dictionary<MapMember, List<long>>();
                selectionDictionary.Add(abLayer as MapMember, selection.GetObjectIDs().ToList());
                moveFeature.Name = "Move features";
                moveFeature.Move(selectionDictionary, 10, 10);  //specify your units along axis to move the geometry
                moveFeature.Execute();
UmaHarano
Hi Brian,
BrianBulla
Thanks Uma.  That is working now.
Do you know if there is a similar method that will move the feature to a specific coordinate??  Or is there a built-in method for calculating the offset between two coordinates??
UmaHarano
Hi Brian
If you use EditOperation's Modify method you can move the point to a specific coordinate -
                var oid = selection.GetObjectIDs().FirstOrDefault();
                var moveToPoint = new MapPointBuilder(1.0, 2.0, 3.0, 4.0, MapView.Active.Map.SpatialReference); //can pass in coordinates.
                var modifyFeature = new EditOperation();
                modifyFeature.Name = "Move features";
                modifyFeature.Modify(abLayer, oid, moveToPoint.ToGeometry());  //Modify the feature to the new geometry
                modifyFeature.Execute();
Also, the GeometryEngine has a "Distance" method that could be used to calculate the offset distance between 2 points (to plug into the "Move" method - For the original Move method snippet).
Uma
BrianBulla
Thanks again Uma.  You have been a great help!
I tweaked yours to work with a selection of features.  Here is my final solution for anyone else who may be following this thread:
// Get the layers and also any selected OIDs for the AsBuilt and the SitePlan layers
                var asBuiltLayer = MapView.Active.Map.FindLayers("GISWRKS1.WORKS.Drawings_AsBuilts").FirstOrDefault() as BasicFeatureLayer;
                // variable for the coordinate of the mouse click in the whatever the SpatialReference of the map is
                var coord = GeometryEngine.Instance.Project(geometry, MapView.Active.Map.SpatialReference) as MapPoint;
                var moveToPoint = new MapPointBuilder(coord.X, coord.Y, MapView.Active.Map.SpatialReference);
                // create counter for showing final results
                int abCount = 0;
                // start the EditOperation
                var modifyAsBuilts = new EditOperation();
                modifyAsBuilts.Name = "Move As-Builts and Site Plans";
                // Get any selected OIDs for the layer, and move each point to the mouse click point.
                if (asBuiltLayer != null)
                    var selectedAB = asBuiltLayer.GetSelection();
                    IReadOnlyList<long> selectedAsbuiltOIDs = selectedAB.GetObjectIDs();
                    foreach (var oid in selectedAsbuiltOIDs)
                        modifyAsBuilts.Modify(asBuiltLayer, oid, moveToPoint.ToGeometry());
                        abCount++;
modifyAsBuilts.Execute();
CharlesMacleod
Brian, thanks for taking the time on this.
FYI: on:
                var moveToPoint = new MapPointBuilder(coord.X, coord.Y, MapView.Active.Map.SpatialReference);<-- not needed
coord is a MapPoint already (reading your code).
So this:
can become this:
modifyAsBuilts.Modify(asBuiltLayer, oid, coord);
I think you may have some copy/paste inheritance from Uma's code where she used a MapPointBuilder because she built the point from scratch.
One other point (no pun intended ;-). I noticed this:
I don't now what the overall context of the "surrounding" code is but I suspect that your digitized geometry may already be in the map spatial reference. Can you just try:
modifyAsBuilts.Modify(asBuiltLayer, oid, geometry);
using the geometry directly and see if that works?
BrianBulla
Hi Charles,
Yes, I was doing some copy/paste without really realizing what the MapPointBuilder was doing.
Anyways.....just using the geometry parameter is working:
One thing I am noticing is that the points in the map don't actually move until I click on 'OK' for the message box that pops up after I run modifyAsBuilts.Execute().....see below:
ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(abCount.ToString() + " As-Builts moved.", "Points moved");
I am guessing that I need some sort of a delay in there for the moving of the points to catch up to the processing of the code.....right??
Now on to the next phase;  figuring out how to enable/disable this tool based on certain layers being in the map or not....and also changing the mouse cursor to the 'Explore' tool after the points have been moved.  Any advice??
CharlesMacleod
If you have this:
QueuedTask.Run(() => {
       op.Execute();
       MessageBox.Show("...");
you probably won't see the move (until after).
Instead, do this:
await QueuedTask.Run(() => {
       op.Execute();
and you will. Note, if you add "await", you must also add "async" to the method declaration (eg SketchComplete or whichever it is).
BrianBulla
Excellent....thanks Charles!
KT81
New Contributor III
Uma,
Thanks for this snippet, I was wondering is it possible to use Attributes from a feature layer that has fields for Lat Longs instead of using specific coordinates?  I have a tool that is working using the above snippet, but I am having difficulties applying the Lat and Long fields to the moveToPoint variable.
