XY table with curve
425
08-23-2017 01:53 PM
AykUnanyan
RouteBegN6BegE6EndN6EndE6DeltaAngle
1001a2428959.9207193482.6002428182.4607193057.4500.00000000
1001a2428182.4607193057.4502427917.2787192760.2990.00000000
1001a2427917.2787192760.2992427623.6157192534.419-21.37387222
1001a2427623.6157192534.4192423390.9607190388.940
0.00000000
B
XY to line not a problem - how about if the table has delta angle?
DanPatterson_Retired
if you plan to make a curve from the above, then you would have to provide the translating equation and generate a polyline..  Is this is some road curvature parameter?
AykUnanyan
It is a centerline of pipeline. If I ignore the delta column the alignment would be just straight line segments, delta column holds the curve angle for that particular segment. The transition is there.  I was wondering if someone had a python code that would read the delta angle also. Thanks for your input
