ArcGIS Python API - create_service
713
08-23-2017 10:58 PM
VassiloWalluschnig1
Hi All,
I am able to create a service from a JSON string using the create_service function, however, I can't seem to create it anywhere else other than in the root folder. How do I tell the function to create it in a different folder?
Regards,
Vassilo.
RohitSingh2
Have you tried using the folder parameter?
VassiloWalluschnig1
Hi Rohit,
Yes, both folder= and folder_name=, both return  - TypeError: create_service() got an unexpected keyword argument 'folder_name'
Regards,
Vassilo
VassiloWalluschnig1
Hi Rohit,
I have not heard back from you in quite awhile. Is this problem a known issue, if so, when will it be addressed. If not, what do I need to do to get it to work.
Regards,
Vassilo
RohitSingh2
Hi Vassilo,
Please update the arcgis package to v1.2.4 which has a fix for this issue.
conda update -c esri arcgis
Rohit
