How can I format PLSS land description records in excel, so that ArcGis can read/interpret the land descriptions to create a shapefile with polygons of the land description records?
1144
09-05-2017 11:23 AM
ShaunHamlin
I am learning to use ArcGIS for land records and I would like to see if there is a way I can show polygons surrounding a land area described in PLSS format. For instance if I had a tract record in the state of Kansas with land description SE/4 SE/4 Section 16 T8S R8W and I wanted a polygon to cover the area described - how would I do this?
Thank you in advance for helping me out.
PLSS‌
land records‌
land surveying‌
#land management
ChrisBuscaglia
Hello Shaun,
Below is a simple configuration of our standard Parcel Viewer to locate PLSS divisions and export them to a variety of formats.  Still more work to be done on this (including adding quarters and quarter/quarters) but it's a good proof of concept for you.
https://arcgis4localgov2.maps.arcgis.com/apps/webappviewer/index.html?id=ab509ef545b6459d95f5eb83f4f...
Locate PLSS Divisions and export screeshots, note that I've pre-populated a search so you can see how it works.
PLSS Locator
While you're at it, you may also want to see what other solutions for land records we have -
http://solutions.arcgis.com/local-government/land-records
Check out the new Parcel Drafter that lets you enter metes-and-bounds if you need to run out any land descriptions.
http://tryitlive-361356583.us-west-2.elb.amazonaws.com/ParcelDrafter/
Chris
Christopher Buscaglia | ArcGIS Solutions
Esri | 380 New York St | Redlands, CA 92373 | USA
THE SCIENCE OF WHERE™
