Error when pushing Blob to Feature service
396
09-13-2017 05:02 AM
FrancisGagne
I'm trying to create a Feature with an esriFieldTypeBlob but it crashes with an UnsupportedOperationException.
The value of the attribute is a byte array.
The FeatureLayer is a Feature service with the edition and addition enabled.
Map<String, Object> attributesMap = new HashMap<>();
for (Attribute attribute : attributeListAdapter.getAllAttribute()) {
    attributesMap.put(attribute.getName(), attribute.getValue());
final FeatureTable featureTable = featureLayer.getFeatureTable();
//the createFeature cause the exception
feature = featureTable.createFeature(attributesMap, sketch.getGeometry());
FATAL EXCEPTION: main Process: com.cgi.cgis, PID: 20311
java.lang.UnsupportedOperationException: Conversion to CoreElement not implemented: class [B
 at com.esri.arcgisruntime.internal.n.g.a(SourceFile:528)
 at com.esri.arcgisruntime.internal.n.k$b.a(SourceFile:452)
 at com.esri.arcgisruntime.internal.n.k$b.add(SourceFile:399)
 at com.esri.arcgisruntime.internal.n.g.a(SourceFile:762)
 at com.esri.arcgisruntime.data.FeatureTable.createFeature(SourceFile:535)
 at com.cgi.cgis.core.edition.manager.EditionManager.createFeature(EditionManager.java:321)
If I put anything else in this attribute, I get a mismatch error, and if I put null, the creation runs fine and I can push it to the service.
AlexanderNohe1
Occasional Contributor III
I will research this and get back to you
