How to add a feature in an existing GeodatabaseFeatureTable
612
09-13-2017 05:35 AM
GaelDurand
I'm trying to add a new feature into an existing GeodatabaseFeatureTable but I get the following error when createFeature is called:
com.esri.arcgisruntime.ArcGISRuntimeException: Cannot call this method in this context
Here is the code:
    // create a new Geodatabase from local path
    mGeodatabase = new Geodatabase(mGeoDb);
    // load the geodatabase
    mGeodatabase.loadAsync();
    // add feature layer from geodatabase to the ArcGISMap
    mGeodatabase.addDoneLoadingListener(new Runnable() {
    @Override
    public void run() {
        for (GeodatabaseFeatureTable geoDbTable : mGeodatabase.getGeodatabaseFeatureTables()){
            java.util.Map<String, Object> attributes = new HashMap<String, Object>();
            attributes.put("COD", "SIG");
            Point gps = new Point(-1.640235, 48.127568, SpatialReferences.getWgs84());
            Feature addedFeature = geoDbTable.createFeature(attributes, gps);
Any help would be appreciated.
AlexanderNohe1
Occasional Contributor III
My assumption is that it is probably not fully loaded yet (need to check with that team).  If you put this in at a different time, say after another button click, does it get inserted correctly?
GaelDurand
I tried to put the following code in an onClick method long after loading features, but the feature doesn't appear. Do I need to use a SyncGeodatabaseTask? If that is the case, I have no clue how to code it...
java.util.Map<String, Object> attributes2 = new HashMap<String, Object>();
attributes2.put("COD", "SIG"); // Coded Values: [0: No] , [1: Yes]
Feature addedFeature = mGeodatabase.getGeodatabaseFeatureTable("CARTO_ETARE").createFeature(attributes2, gps);
final ListenableFuture<Void> addFeatureFuture = mGeodatabase.getGeodatabaseFeatureTable("CARTO_ETARE").addFeatureAsync(addedFeature);
addFeatureFuture.addDoneListener(new Runnable() {
    @Override
    public void run() {
