System End Date shows date only, lacks time
454
09-14-2017 07:24 AM
JeffWard
Occasional Contributor III
I was just noticing the SystemEndDate field in the parcel fabric just shows the date, but lacks the time. The other system date fields (SystemStartDate, ModifyDate) all show the time. Just wondering if this is an oversight, I don't know that it matters a great deal, just thinking it would be nice to have things be consistent.
Jeff Ward
Summit County, Utah
AmirBar-Maor
Thanks Jeff.
Good catch - they should be consistent. This happens because some of the fields are controlled by the parcel fabric and the other by editor tracking (if activated).
And like you - I don't know that it matters much, certainly does not justify a schema bump.
Amir
JeffWard
I noticed the issue because a subdivision wasn't showing up as historic after I made it historic (it was actually an issue with the default definition query for the historic layer not showing the sub or condo type). To make a long story short, I had two historic subdivisions that were the same and I thought it would be nice to see which system end date was older.
Jeff Ward
Summit County, Utah
