Extensions not working in debug mode
669
09-19-2017 01:16 AM
Min_KenMoey
HI, I'm trying the dashboard extensions from https://github.com/Esri/dashboard-samples. In debug mode, after i added e.g. a table widget into the dashboard, all i get is a a blank space. This is using the latest operations Dashboard 10.3.4.1523. How do i get a custom extension working again? I last tried it late last year, it was working then.
ChristopherOlsen
Occasional Contributor III
Hi Ken,
Can you try the solution in this KB article?
Problem: Unable to load custom extensions after installing and launching Operations Dashboard for Ar...
I think this is what is causing your issue.
Chris
ChristopherOlsen
Can you try the following:
  • If you are signed into the org using https, please try using http
  • do other extensions work?
  • Click the triangle on the widget to launch debug. do you have any errors?
  • What OS are you using?
  • If you save it and launch the browser, does that work?
Thanks!
Chris
Min_KenMoey
Hi Chris,
1) Used http for my portal, still didn't work
2) Nope, no extension work. I tried to build my own simple one, also didn't work.
3) The debug window appears blank to me as well
4) Win 10
5) Yes, browser mode works; it's the only way i can proceed with my development now.
Regards,
Ken Moey
ChristopherOlsen
Hi Ken,
Chris
Min_KenMoey
That actually worked. So operations dashboard needs the gpu, if two graphics cards are presnet.
