Hi.
I tried used HTML font size or color and it seems broken. It works for Map Tour but not Map Shortlist? Please see screenshot. Thank you.
Solved! Go to Solution.
Hi Alexis,
Shortlist does not support adding HTML tags. If you need to customize the look and feel of your Shortlist, you can download the source code from our GitHub Repo, make some modifications in the index.html file (there is a placeholder around line 76 to add custom css rules), then host on your own server.
Mark
Hi Alexis,
Mark
