Hello, i have created a layer of public toilets in my area and did so by creating a shapefile and mapping the points where the toilets where, how do i add information to each point such as opening hours etc?
515
09-21-2017 04:54 AM
alexbell4
Hello, I have created a layer of public toilets in my area and did so by creating a shape file and mapping the points where the toilets where, how do I add information to each point such as opening hours etc?
DanPatterson_Retired
Basically, you can add fields to the attribute table and add the information manually there. Or you can join an appropriate table to that file.
I assume that this is your first foray into GIS, so I would recommend the former approach beginning with Adding Fields to tables
alexbell4
Further to this, after I have entered the field name into the table along with the data such as the address. How do I get the data to pop up when I hover my mouse over it or click on the point. For example : https://www.causewaycoastandglens.gov.uk/see-do/harbour-and-marinas/harbour-maps
Thanks in advance.
Hyperlinks is one option  and another... but your question is beginning to sound it will continue, so finish one phase and return with questions when you enter a new phase
