Sentinel2
953
09-21-2017 02:00 AM
SanneDouma
I would like to use the tool 'Sentinel2 Script'. I used the default selection 'Multispectral-10m' and 'Define and Build Overview'. I am using ArcGIS 10.4.1.
From the Copernicus Open Access Hub I downloaded the set 'S2A_OPER_PRD_MSIL1C_PDMC_20161028T094458_R020_V20161026T064952_20161026T064952'.
When I run the tool I get the following error message. Does anyone know what the problem could be?
Executing: Sentinel2 C:\Documents\ArcGIS\Sentinel.gdb _M10 C:\Documents\ArcGIS\Sentdata true false false false true
Start Time: Thu Sep 21 10:46:01 2017
Running script Sentinel2...
log-msg: Using template:C:\Documents\ArcGIS\Sentinel2/Parameter/Config/sentinel2\GP_S_Sentinel2_MS_10.xml
log-msg: Processing command(s):CM+AF+AR+CV+CC+BF+BB+SP+DO+BO
log-msg: Command:CM->Create a new mosaic dataset.
log-msg: Creating Geodatabase: (C:/Documents/ArcGIS/Sentinel.gdb)
log-msg:   000258: File geodatabase already exists!
log-msg: Creating source mosaic datasets:
log-msg:   _M10MS_10
log-status: OK
log-msg: Command:AF->Add fields.
log-msg: Adding custom fields:
log-msg: Using mosaic dataset:_M10MS_10
log-msg:   Creating fields:
log-msg:        Dataset_ID
log-status: OK
log-msg: Command:AR->Add rasters/data to a mosaic dataset.
log-msg: Adding rasters:
log-msg:   Using mosaic dataset/ID:_M10MS_10/Sentinel2_10
log-msg:   Using ART for _M10MS_10: C:\Documents\ArcGIS\Sentinel2\Scripts\Base\..\..\parameter\Rastertype\Sentinel2_MS_10.art.xml
log-msg: Adding items..
log-msg: Calling (arcpy.AddRastersToMosaicDataset_management)
log-msg: Status: OK
log-msg: No new mosaic dataset item was added for Dataset ID (Sentinel2_10)
log-critical: No new mosaic dataset items added to dataset (_M10MS_10). Verify the input data path/raster type is correct
log-critical: Executing: AddRastersToMosaicDataset C:/Documents/ArcGIS/Sentinel.gdb\_M10MS_10 C:\Documents\ArcGIS\Sentinel2\Scripts\Base\..\..\parameter\Rastertype\Sentinel2_MS_10.art.xml C:\Documents\ArcGIS\Sentdata NO_CELL_SIZES NO_BOUNDARY NO_OVERVIEWS # 0 1500 # *S2A*.xml SUBFOLDERS ALLOW_DUPLICATES NO_PYRAMIDS NO_STATISTICS NO_THUMBNAILS # NO_FORCE_SPATIAL_REFERENCE NO_STATISTICS #
Start Time: Thu Sep 21 10:46:28 2017
2017-09-21T10:46:29.168: Loading raster datasets
2017-09-21T10:46:30.355: Completed crawling 0 data source items. Added 0 mosaic dataset items.
2017-09-21T10:46:30.361: Error: 8004205f: No new mosaic dataset item was added.
Succeeded at Thu Sep 21 10:46:30 2017 (Elapsed Time: 1,95 seconds)
log-status: Failed!
log-msg: Done...
Completed script Sentinel2...
Failed to execute (Sentinel2).
Failed at Thu Sep 21 10:46:35 2017 (Elapsed Time: 33,85 seconds)
DanPatterson_Retired
don't know about the script you are referring to.. (link?? )
but http://desktop.arcgis.com/en/arcmap/latest/tools/data-management-toolbox/create-mosaic-dataset.htm can be used, it lists Sentinel2 specifically
