AGOL Assistant is Offline
722
09-21-2017 05:44 AM
Lake_Worth_BeachAdmin
Occasional Contributor III
https://ago-assistant.esri.com/
when you try to login with AGOL you get this: the server needs to be fixed. Someone at ESRI please inform the responsible team.
ignore my previous response, I realized I can in fact use my AGOL org. URL to access this via the portal login
awesome!
CarmelConnolly
Hi Joe,
I can see this issue as well.
The Portal for ArcGIS login still works - the interface has a few changes so this issue could be coinciding with the latest release of ArcGIS Online.
Carmel
Ok I don't use portal though so that doesn't help me (unless I can use that prompt to access agol?)
I needed to use this interface for a live demo today for a meeting to supervisors and now I am out of luck
awesome!
