Editing cursor won't change back to black
1506
09-22-2017 08:59 AM
ElizabethHigh
New Contributor III
I'm using ArcGIS for Desktop v 10.5 and editing features in a file geodatabase.
When I'm in EDIT mode and I choose "Edit vertices..." the cursor turns from the black arrow to the white arrow. Normally, when I'm done in "Edit Vertices," I do "Save edits" and the cursor jumps back to black and allows me to select and move whole features again.
However, now (as of the last couple of days) it won't change back to black, so I can no longer select the feature. Even if I stop and restart the editing session, the cursor is still white. The only way I can get the black cursor back is to close out my MXD and re-open, which is obviously frustrating and not efficient.
Are there any mouse strokes or keystrokes to force the cursor back to the black mode?
arcmap editing‌ selection cursor cursor #editvertices #editingcursor
MichaelGammon
Did you ever find a solution to this problem? I am experiencing the same thing right now and it is very frustrating!
MichaelGammon
If you select one feature then click the edit vertices button twice, to turn it on and back off, the cursor will go back to black and you can resume moving features.
