How do I add SDE layer to ArcGIS Pro 2.0 ?
2930
7
09-22-2017 10:30 AM
PROBERT68
How can I add SDE to ArcGIS Pro ? I imported a mxd to my ArcGIS Pro and I need to add them because a few of them had broken links ( Those red exclamation Points ).
AdrianWelsh
MVP Honored Contributor
Robert,
First you need to connect to the SDE database. Here are instructions for doing this:
Connect to a database—ArcGIS Pro | ArcGIS Desktop
Then you can add data from the SDE.
PROBERT68
Don't know why my ArcGIS Pro 2.0 does not read and it says it is empty  with red exclamation point next to it.
George_Thompson
Esri Frequent Contributor
Is there any error when you double click the connection?
--- George T.
PROBERT68
Yes, when I double click on it and then the next thing it says This container is empty. Even though I know the feature classes are there.
George_Thompson
What is the version of the geodatabase?
What is the RDBMS and version being used?
Does the same issue occur when connecting in ArcMap 10.5.1?
--- George T.
PROBERT68
It is hard to say. I work for the USDA Forest Service.
We use ArcGIS 10.3.1 right not but we will pretty sure go upgrade to 10.5.1. The exactly date is unknown.
Type of Database is Oracle Enterprise Geodatabase.
PROBERT68
BTW, I just export each of the SDE into a File Geodatabase. That works so that is the only way around at this time.
