ERROR 000539: Raster Calculator in Model Builder
1725
09-22-2017 04:27 PM
MichelleTanner2
the red highlighted tool is where I am getting the error. but #s 1-4 also use Raster CalculatorHello,
I am trying to run Raster Calculator in Model Builder, however I am getting what looks like two errors after my model reaches a certain step. I'm not sure if it is a syntax issue or something else.. Raster Calculator is used in earlier steps in the same model with no problem. Could someone please help with my syntax? Below is what I wrote:
  (Power("%P95%"-"%Ia%"*"%S05g%",2)) /("%P95%"+(0.95*"%S05g%"))
Note: P95 and Ia are parameters, and S05g is a dataset raster that is calculated in the previous step.
I then get this error message:
ERROR 000539: Error running expression: rcexec() Traceback (most recent call last):  File "<expression>", line 1, in <module>  File "<string>", line 5, in rcexec  File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\sa\Functions.py", line 4485, in Times    in_raster_or_constant2)  File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\sa\Utils.py", line 53, in swapper    result = wrapper(*args, **kwargs)  File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\sa\Functions.py", line 4482, in Wrapper    ["Times", in_raster_or_constant1, in_raster_or_constant2])RuntimeError: ERROR 000732: Input Raster: Dataset 0.05 does not exist or is not supported
Failed to execute (calculate Q95g).
What's going on here? I originally wrote the expression with '**' instead of 'Power(,)', but that also presented me with the same error. I am using ArcGIS Pro 2.0 if that helps.
Thanks!
curtvprice
MVP Esteemed Contributor
If P95 and Ia are numbers they should not have quotes around them. You have Raster Calculator looking for a raster layer or dataset named ".05". This may work better.
(Also check the parentheses I added to the left expression -- the parentheses I added will make it work the way you wrote it.)
Power(%P95% - (%Ia% * "%S05g%"), 2) / (%P95% + (0.95 * "%S05g%"))
