Communications Utility Network Foundation (Esri)
27050
74
09-22-2017 09:00 PM
SpatialNinja
The Esri team is continuing to refine and improve the data model for comms data management on ArcGIS Utility Network Management. Use this thread to provide input on the requirements of the data model, capabilities of the telecom network, ask questions about the network, access early versions of data models, and stay up to date on the latest news.
Communications Utility Network Foundation (Story Map)
Communications Utility Network Foundation Workflows (Story Map)
PNI ModelsStatus Last UpdatedSoftware Requirements
Fiber, Coax, Copper, WirelessVersion 1.3 Released November 20223/27/2023Introduction to Communications Utility Network Foundation - Requirements
Join the Discussion Below!
- Esri Telecom Team
 telecominfo@esri.com
Solutions Engineer | Spatial Ninja  | GIS ️ | Telecommunications
SpatialNinja
New white paper describing the road ahead for network management: http://www.esri.com/library/whitepapers/pdfs/road-ahead-for-network-management.pdf
SpatialNinja
Great blog on the top 10 capabilities coming in the ArcGIS Utility Network Management Extension.
https://community.esri.com/people/pdemer-esristaff/blog/2017/12/14/top-ten-things-about-the-utility-...
SpatialNinja
The Utility Network Management Extension has been release at 10.6!
ArcGIS Utility Network Management | Location-Based Asset Management
This initial release will support electric, water, and gas.  We are currently scoping out the requirements for the Telecom Network.  If you have requirements for managing your fiber networks, please let us know here.
SpatialNinja
Vision and Overview of the Utility Network
With the release of ArcGIS Enterprise 10.6 and ArcGIS Pro 2.1, the Utility Network Management extension is offered as a comprehensive solution to managing utility and telecom networks (telecom model not available with first release). Core tools within the Utility Network Toolbox can be used to create and configure the utility network. For automation purposes, the Utility Network Package Tools from the ArcGIS solutions team are available with asset packages for electric, gas, and water domains. Learn More: https://blogs.esri.com/esri/arcgis/2018/01/23/vision-and-overview-of-the-utility-network/
JoeKilzer
My requirement feedback would be to ensure that it aligns with the old Telecom data model and provides tools that align to at the least the old Telecom tools. We have built our tools and schema around this. Thank you!
GregHunt
Hi supportUPN‌ I would love to connect with you to understand your needs. Please reach out to me, ghunt@esri.com
AbhijeetKulkarni
Would strands still be represented by logical tables in UN going forward?
SpatialNinja
GHunt-esristaff
GregHunt
Hi abhijeet‌-- We are working on defining the data model for the telecom solution. Please reach out to me directly, ghunt@esri.com so we can discuss your need and questions.
