How to update graphic location as you drag (ArcJSAPI 4.4)
1714
09-25-2017 03:36 PM
DevonCanady
I'm trying to click a feature to select it and then drag it to a new location. Currently the location of the graphic only updates when I let go even though I have the coords updating as it moves (when evt.action == "update"). I'm wondering how to make the graphic follow the cursor as I drag it.
view.on("drag", function(evt) {
   switch(evt.action) {
      case "update":
      evt.stopPropagation(); //to stop map panning, same issue with this or not
      var screenPoint = { x: evt.x, y: evt.y };
      view.hitTest(screenPoint).then(function(response) {
         updateSelectedFeatureGraphic(view.toMap(screenPoint));
   break;
function updateSelectedFeatureGraphic(geometry) {
   if (selectedFeatureGraphic)
      removeSelectedFeatureGraphic();
   selectedFeatureGraphic = new Graphic({
      geometry: geometry,
      symbol: new SimpleMarkerSymbol({
         style: "circle",
         color: "#80ffff",
         size: "12px", outline: {
            color: "#80ffff",
            width: 1
   view.graphics.add(selectedFeatureGraphic);
function removeSelectedFeatureGraphic() {
   view.graphics.remove(selectedFeatureGraphic);
   selectedFeatureGraphic = null;
ThomasSolow
Occasional Contributor III
Here's a sample that does this: JS Bin - Collaborative JavaScript Debugging
Only works on point graphics.  Graphics will other geometries will be more involved but also possible with a little work.
ThomasSolow
DevonCanady
Looks like I didn't need to be doing a hit test for the update action type. Thanks!
