On complete query task event contains many query tasks
1068
09-26-2017 02:49 AM
SaraEL_MALKI
Occasional Contributor II
Hi guys,
I am struggling with same problem since I started using the API,
my concept is: I wanna make a query which has some results, for each result I wanna do another query, and for each result of that last query I wanna do some instructions so the idea is that the hole process is based on the first query, whenever I finish my instructions I wanna display the object id of the FIRST QUERY which lead me to the last one,
When I try this in the API, I notice that it doesn't happen like that instead they run all the queries, then they go to the second then to the third as if they's not inside each other, I'll give you the code which I am using to draw a dojo chart, that you can understand my problem clearly,
In the code below I wanna for Each Collection circuit, Search if it has Sections then If it does, Search for each Section if it has bags, then for each bag look if it has a "C" or "NC" in a column then calculate the SUM of the bags having "C" and those having "NC" in the COLLECTION CIRCUIT,
so I need an ARRAY containing the name of the circuit and the sum of C and NC bags,
the code below is giving me the sum of C and NC bags for each SECTION  not for each Collection Circuits,
please HELP ME and clarify what's the error that I'm doing !
Thomas Solow‌ John Zhang  Robert Scheitlin, GISP Rebecca Strauch, GISP
function do_the_magic_1(){
array_id_troncon=[];
var queryCircuit_6 = new Query();
var QTask_Collecte = new QueryTask("..../MapServer/1"); //Collection Circuits
var queryTaskCircuit_6 = new QueryTask("..../MapServer/11"); //SECTIONS
var queryTaskBac_6 = new QueryTask(".../MapServer/6"); //BAGS
queryCircuit_6.where = "direction IS NULL AND renfort_repassage = 0 AND arrondissement='MGHOGHA'"
queryCircuit_6.outSpatialReference = {wkid:102100};
queryCircuit_6.returnGeometry = false;
queryCircuit_6.outFields = ["*"];
QTask_Collecte.execute(queryCircuit_6); // We have found all the "Collection Circuits"
QTask_Collecte.on("complete",function(eventCircuitCol){
var fsetCircuitC = eventCircuitCol.featureSet;
var FeaturesCC = fsetCircuitC.features;
for (var i = 0, len = FeaturesCC.length; i < len; i++) { // for each Circuit => Search if it has a Section
var FeatureCC = FeaturesCC[i];
queryCircuit_6.where = "id_circuit_collecte='"+FeatureCC.attributes['objectid']+"'"; //Sections of the circuit
queryTaskCircuit_6.execute(queryCircuit_6); //We have found all the sections of that circuit
queryTaskCircuit_6.on("complete",function(eventTroncon){
var fsetTroncon = eventTroncon.featureSet;
var FeaturesTr = fsetTroncon.features
for (var ii = 0, leni = FeaturesTr.length; ii < leni; ii++) { //for each Section => Search if it has Bags !
var featureTr = FeaturesTr[ii];
var queryBac_6 = new Query();
queryBac_6.where = "id_troncon='"+featureTr.attributes['id_troncon']+"'"; //BAGS that belongs to the section
queryBac_6.outSpatialReference = {wkid:102100};
queryBac_6.returnGeometry = false;
queryBac_6.outFields = ["*"];
queryTaskBac_6.execute(queryBac_6,function(fset){
conforme_oui_1=0; // I wanna initialise these too variables whenever I change the Collection Circuit
conforme_non_1=0;
for(i=0;i<fset.features.length;i++){ // For each bag => look if it has a "C" or "NC" in a specific column
var featureBac=fset.features[i];
if(featureBac.attributes['positionnement']=='C'){
conforme_oui_1=conforme_oui_1+1;
else if(featureBac.attributes['positionnement']=='NC'){
conforme_non_1=conforme_non_1+1;
Conforme_oui_Array.push(conforme_oui_1);
Conforme_non_Array.push(conforme_non_1);
//Rendering
chartPos_ParCircuit.addSeries("Series A", Conforme_oui_Array, {color:"green"} ).addSeries("Series B", Conforme_non_Array,{color:"red"}).render();
}); //end on complete
} //end function //
RobertScheitlin__GISP
Sara,
   So it sounds like you want to complete the second, third and fourth queries before you proceed to the next circuit. If that is the case then you want to modify your workflow to not do the next circuit OID result query until all the subsequent queries are complete. Try this (it is untested and my needs some work still):
function do_the_magic_1() {
  array_id_troncon = [];
  var id_circuit_array = [];
  circuitIndex = 0;
  queryCircuit_6.where = "direction IS NULL AND renfort_repassage = 0 AND arrondissement='MGHOGHA'";
    wkid: 102100
  QTask_Collecte.execute(queryCircuit_6, function(eventCircuitCol) {
    for(var i = 0, len = FeaturesCC.length; i < len; i++) { // for each Circuit => Search if it has a Section
      id_circuit_array.push(FeatureCC.attributes['objectid']);
    Query2(id_circuit_array[circuitIndex]);
  function Query2(oid) {
    conforme_oui_1 = 0; // I wanna initialise these too variables whenever I change the Collection Circuit
    conforme_non_1 = 0;
    queryCircuit_6.where = "id_circuit_collecte='" + oid + "'"; //Sections of the circuit
      wkid: 102100
    queryTaskCircuit_6.execute(queryCircuit_6,function(eventTroncon){
      var FeaturesTr = fsetTroncon.features;
        Query3(featureTr.attributes['id_troncon']);
    }); //We have found all the sections of that circuit
  function Query3(id_troncon) {
    queryBac_6.where = "id_troncon='" + id_troncon + "'"; //BAGS that belongs to the section
      wkid: 102100
    queryTaskBac_6.execute(queryBac_6, function(fset) {
      for(i = 0; i < fset.features.length; i++) { // For each bag => look if it has a "C" or "NC" in a specific column
        var featureBac = fset.features[i];
        if(featureBac.attributes['positionnement'] == 'C') {
          conforme_oui_1 = conforme_oui_1 + 1;
        } else if(featureBac.attributes['positionnement'] == 'NC') {
          conforme_non_1 = conforme_non_1 + 1;
      circuitIndex++
      if(circuitIndex < id_circuit_array.length - 1){
      }else{
        //Rendering
          color: "green"
        }).addSeries("Series B", Conforme_non_Array, {
          color: "red"
        }).render();
} //end function //
Sara,
   I am not sure I completely follow but what happen if you nest all the queries like this:
    wkid: 102100
  QTask_Collecte.execute(queryCircuit_6, function(eventCircuitFS){
    var FeaturesCC = eventCircuitFS.features;
      queryCircuit_6.where = "id_circuit_collecte='" + FeatureCC.attributes['objectid'] + "'"; //Sections of the circuit
        wkid: 102100
      queryTaskCircuit_6.execute(queryCircuit_6, function(fsetTroncon){
        for(var ii = 0, leni = FeaturesTr.length; ii < leni; ii++) { //for each Section => Search if it has Bags !
          queryBac_6.where = "id_troncon='" + featureTr.attributes['id_troncon'] + "'"; //BAGS that belongs to the section
            wkid: 102100
            conforme_non_1 = 0;
            //Rendering
              color: "green"
              color: "red"
            }).render();
  }); // We have found all the "Collection Circuits"
} //end function //
SaraEL_MALKI
No actually that was my first idea but it didn't work at all,
to understand why I've added "alert" like above, I get 10 alerts consecutively giving the Circuit Id (I have 10 Circuits matching the condition) , and after them I get MANY alerts of the sections,
What I want is having One alert of the Id circuit then many alerts of the section then, another alert of the circuit then many alerts of the section  ...
    wkid: 102100
            conforme_non_1 = 0;
alert('Circuit ID is'+FeatureCC.attributes['layer']);
        wkid: 102100
alert('Section is found');
            wkid: 102100
            //Rendering
              color: "green"
              color: "red"
            }).render();
} //end function //
Sara,
  circuitIndex = 0;
    wkid: 102100
    conforme_non_1 = 0;
      wkid: 102100
      wkid: 102100
      circuitIndex++
      }else{
        //Rendering
          color: "green"
          color: "red"
        }).render();
} //end function //
SaraEL_MALKI
thank you mister Robert for your time, your question has helped me no doubt in getting what I wanted, many thanks
