How to read japanese characters in DBF
3014
5
01-18-2011 07:49 PM
ErosSy
I am not sure if the Forum is correct but I am stuck with reading a dbf but the data are garbled.
I successfully created a shp,shx and dbf compatible with esri. Then now, I am creating a java application that reads the 3 files for further processing.
please guide me on how to read a dbf file correctly.
Thanks in advance.
BruceHarold
Hi
If your DBF file is part of a shapefile, then you will need a codepage file to correctly interpret any Unicode strings.  If your shapefile root name is "xyz" then create a text file xyz.cpg with the contents "UTF-8" (not quoted) and hopefully that will work for you.
Regards
ErosSy
hi bruce_harold,
Thanks a lot. but I can't understand when the .cpg file reads.
The java app that I am working is an internal app that convert the shape(shp,shx,dbf) to gml3.2.1.
BruceHarold
Hi
Only ESRI applications or SDK's will understand the CPG file, you may have to handle the Unicode encoding yourself in another environment.
Regards
ErosSy
Thanks a lot..
I just thinking that there is an available api from esri to read the dbf correctly.
With appreciation
V_StuartFoote
MVP Frequent Contributor
In addition to Bruce's response, please see this similar thread regards your question.
http://forums.arcgis.com/threads/21617-Japanese-characters-in-attribut-table-not-showing-properly?p=...
Stuart
