Best method to display AutoCAD DWG in Flex Viewer?
2782
01-20-2011 10:45 PM
TravisGoad
Hey guys,
I need to be able to publish DWG linework to a FlexViewer, retaining all symbology etc.
What is the best way to do this ?
Thanks!
TravisGoad
No suggestions?
I've tried representing the symbology as close as possible in ArcGIS, but the intervals between dashes etc. will never be as accurate as the DWG.
JuanLuera
Occasional Contributor III
Hola Travis,
The Flex Viewer is design to display services, as you can see within the following documentation. My suggestion on this would be to either convert the dwg to shapefile, feature class, etc. and then publish it, where you will be able to display the data within the Flex Viewer. If you have any further questions or issues, please submit a case with Support Services. Gracias, Travis!
ArcGIS Viewer for Flex
http://resources.arcgis.com/en/communities/flex-viewer/
Welcome to ArcGIS Viewer for Flex
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#//01m300000015000000
Esri Support
Juan
