ArcMap IDs for ArcGIS 10
794
6
01-24-2011 06:51 AM
Nik_Mohd_FadhilNik_Mohd_Kamil
New Contributor III
Hi!
I'm trying to build the ArcMap Add-Ins using VB.NET.
How to add command button "Undo", "Redo", and "Save" by using GUIDs? Is my code or GUIDs wrong?
Below is my XML code; it only display "AddData', "ClearSelectionCommand" and "SelectAllCommand" button on my custom (add-ins) toolbar.
          <Items>
            <Button refID="esriArcMapUI.ClearSelectionCommand" />
            <Button refID="esriArcMapUI.SelectAllCommand" />
            <!--File_AddData Command; refID can be GUID"-->
            <Button refID="{E1F29C6B-4E6B-11D2-AE2C-080009EC732A}" />
            <!--Edit_Undo Command; refID can be GUID"-->
            <Button refID="{FBF8C3FB-0480-11D2-8D21-080009EE4E51}"/>
            <!--Edit_Redo Command; refID can be GUID"-->
            <!--File_Save Command; refID can be GUID"-->
            <Button refID="{119591DB-0255-11D2-8D20-080009EE4E51}"/>
          </Items>
SteveVan_Esch
Hi. Adding the subtype attribute manually to the xml should make this work.  Note, the subtype attribute is missing from the schema at 10.0 but it is honored, I'll see about getting this fixed in sp2.
        <Toolbar id="Steve" caption="Steve" showInitially="true">
          <Items>
            <Button refID="{E1F29C6B-4E6B-11D2-AE2C-080009EC732A}" subtype="1" />
            <Button refID="{FBF8C3FB-0480-11D2-8D21-080009EE4E51}" subtype="1" />
            <Button refID="{119591DB-0255-11D2-8D20-080009EE4E51}" subtype="1" />
          </Items>
        </Toolbar>
      </Toolbars>
New Contributor III
Thanks vanesch! it's working now! 🙂
          <Items>
          </Items>
        </Toolbar>
      </Toolbars>
New Contributor III
BTW, is that possible to rename the existing caption of ESRI ArcMap GUID into my own custom name?
e.g. I want to rename the "Open" caption into "Open Company Project MXD"
<Items>
<!--File_Open Command; refID can be GUID"-->
<Button refID=" {119591DB-0255-11D2-8D20-080009EE4E51}" subtype="2" />
</Items>
</Toolbar>
</Toolbars>
New Contributor III
Does anyone know how to rename the existing caption of ESRI ArcMap GUID into custom name?
<Items>
</Items>
</Toolbar>
</Toolbars>
LukeBadgerow
this may not be the right thread to follow on with this question, but anyway.  I've created an add in that I need to break out into any number of plug ins (I need to break them up for security purposes), but common to all of the plug ins is a Root Menu.  How do I get the particular subtype for a specific part of one of those plug ins?
StanShelton
Why are the UIDs of the Undo and Redo commands the same?
