RasterConversionOpClass ToRasterDataset into Memory
500
01-26-2011 04:33 AM
FabrizioPuddu
Is possible to use ToRasterDataset with workspace into memory ?
        Dim pTransformationOp As ITransformationOp = New ESRI.ArcGIS.GeoAnalyst.RasterTransformationOp
        Dim pWSF As IWorkspaceFactory = New InMemoryWorkspaceFactory
        Dim pWS As IWorkspace = Nothing
        Dim pWorkSpaceName As IWorkspaceName
        Dim pName As IName
        Dim pGeoDS As IGeoDataset = Nothing
        Dim rasterWorkspaceFactory As New RasterWorkspaceFactoryClass()
        Dim rasterWorkspace As IWorkspace = Nothing
        Dim rasterConversionOp As New RasterConversionOpClass()
        Dim pRasterEnv As IRasterAnalysisEnvironment = Nothing
        Dim pEnvelopeClip As IEnvelope = Nothing
            pEnvelopeClip = IncreseEnvelope(pPolygon.Envelope, iPercentageIncreseAreaClip)
            pRasterEnv = CType(pTransformationOp, IRasterAnalysisEnvironment)
            pRasterEnv.SetExtent(esriRasterEnvSettingEnum.esriRasterEnvValue, pEnvelopeClip)
            pTransformationOp = pRasterEnv
            pGeoDS = pTransformationOp.Clip(pRasterTerrainSurface, pEnvelopeClip)
            pWorkSpaceName = pWSF.Create("", cFileNameSurfaceAreaClip, Nothing, 0)
            pName = TryCast(pWorkSpaceName, IName)
            pWS = TryCast(pName.Open, IWorkspace)
            ClipLayerSurfaceOnAOI = rasterConversionOp.ToRasterDataset(pGeoDS, "TIFF", pWS, cFileNameSurfaceAreaClip)
thanks at all
fabrizio
DuncanHornby
MVP Notable Contributor
Fabrizio,
You cannot create a raster in an InMemory workspace. If you look at the VBA Help file and search InMemoryWorkspaceFactory CoClass is states what it cannot support, rasters being one of them.
Duncan
FabrizioPuddu
Thanks Duncan, You are right, I forget this,  I didn't re-consulted the documentation.
thanks
Fabrizio
MiguelSouto
Fabrizio,
I have been in a similar problem, concerning the creation of a raster using only the memory, or in other words, not using the rasterdataset object, that needs a directory to be created.
Maybe you already pass in the same problem? If yes, did you found a solution?
Thanks in advance, and ideia would be perfect, since I'm really without solutions.
Miguel
