Hi
I have got a Silverlight App that displays hundrets of different Point-Features in my map.
The Attributes of the Points just consist of Name and Coordinates.
Because of the fact that with ArcGIS Server 9 i cant access "normal" tables that are part of my MXD (Am i right that this is featured in ArcGIS Server 10?), i created a SQL Server Database with different tabels. In This table i have a lot of Attributes for the different Points in my Point-Feature. So for each Point there are n-Entrys in the SQL Table.
My Problem is now, that i need to highlight the Features in my map that have specific attribute values in the SQL Server Table. So in the SQL Server table there are for example Height-Attributes. Now i would like to highlight every point with a Hight greater then 20meters.
I have no Idea how i can realise this effective. The only way i thought about is a Find-Task in my Silverlight App. So first i filter the Data in the SQL Table for every entry greater 20meters. Then i extract the Point-Name of those Entrys.
After that i can do a Find-Task for every Entry. Problem is, that i only can enter one specific SearchText for the Find-Task. So i have to execute the Find-Task for EVERY (maybe 200) Point specifically, but that takes to much time.
Any Ideas? Hope you understand the whole Problem,...i reallly need help!
