The following script takes 3 min to complete in Python on a shapefile that has 211 features. In Arc as a script in a Toolbox it takes 25 min 😞 Arc sits there when it gets to writing a particular feature and I'm not sure why. Is there extra checking and processing that occurs behind the scenes when you run a script as a tool in Arc?The script is pretty basic and I know there are some improvements I could do to speed it up; such as utilising a dictionary, so I'm not repeating MakeFeatureLayer for rows that have the same Area_m2 value, and actually working out how to query based on [Shape_Area], and get it to work! However, if it took 3 min in Arc I'd be happy.Any insights into this would be much appreciated.import arcpy
import sys
# Variables defined by the user
infc = arcpy.GetParameterAsText(0)
FGDBlocation = arcpy.GetParameterAsText(1)
FGDBname = arcpy.GetParameterAsText(2)
outfcname = arcpy.GetParameterAsText(3)
##lyrfile = arcpy.GetParameterAsText(4)
# Set other variables
##lyrfile = "G:\\GIS\\ModelBuilder\\Count_overlaps_tool\\CountOverlaps.lyr"
FGDB = FGDBlocation + "\\" + FGDBname + ".gdb"
output = FGDB + "\\" + outfcname
unionout = FGDB + "\\union"
try:
# Run repair incase of empty geometries and self intersects
arcpy.RepairGeometry_management(infc)
## print "Repaired geometry"
# Create File Geodatabase to hold output featureclass
arcpy.CreateFileGDB_management(FGDBlocation, FGDBname)
## print "Created FGDB"
# Create temporary layer in memory for processing
arcpy.MakeFeatureLayer_management(infc, "in_memory\temp")
## print "Created temp layer"
# Union featureclass to process overlaps
arcpy.Union_analysis ("in_memory\temp", unionout)
# Create new field for storing overlap count to be populated
arcpy.AddField_management(unionout, "Count", "SHORT", "2")
arcpy.AddField_management(unionout, "Area_m2", "TEXT", "", "", "15")
## print "Added fields"
# Populate the new field
arcpy.CalculateField_management(unionout, "Area_m2", "round(!Shape_Area!, 1)", "PYTHON_9.3")
except:
print arcpy.GetMessages()
## print "error"
# Delete unrequired fields
arcpy.DeleteField_management(unionout, ["Id", "FID_Treatment", "Area", "Hectares"])
##print "Deleted fields"
arcpy.MakeFeatureLayer_management(unionout, "in_memory\union")
# Create attribute index to speed up querying??
arcpy.AddIndex_management("in_memory\union", "Area_m2", "Area_m2Index")
# Setup cursor for update
rows = arcpy.UpdateCursor("in_memory\union", "", "", "Count; Area_m2")
for row in rows:
# Get the value from the Shape Area field
area = row.getValue("Area_m2")
# Clause used to create selection later
clause = "\"Area_m2\" = " + "'" + area + "'"
## print clause
# Create temporary layer of all features with the same Area_m2 field value
arcpy.MakeFeatureLayer_management("in_memory\union", "in_memory\temp", clause)
# Count number of identical features to be used to populate count field
featcount = arcpy.GetCount_management("in_memory\temp")
## print featcount
# Populate the Count field with the number of overlaps
row.Count = str(featcount)
# Update the row to write the Count value to the field
rows.updateRow(row)
else:
print "End of rows"
try:
# Delete identical features
arcpy.DeleteIdentical_management(unionout, ["Area_m2"])
## print "Deleted duplicates"
# Copy feature class from memory to a physical location
arcpy.CopyFeatures_management("in_memory\union", output)
## print "Copied features"
arcpy.Delete_management(unionout)
arcpy.Delete_management("in_memory\temp")
arcpy.Delete_management("in_memory\union")
## print "Deleted redundant and temporary layers"
except:
del row
del rows
