I will post the script that i used. I think that it ended up working but can't remember for sure since it was almost a year ago.
# Converts multiple DGN TIN files to ESRI elevation raster
# Mark Wilson
# May 2011
# Imports
import os
import time
import sys
import arcpy
# Check out any necessary licenses
arcpy.CheckOutExtension("3D")
# Set environments
# Variables
DGN_folder = r"D:\"
output_folder = r"D:\"
sr = "PROJCS['HENNEPIN COUNTY',GEOGCS['GCS_User_Defined',DATUM['D_User_Defined',SPHEROID['User_Defined_Spheroid',6378418.941,298.2572242549207]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Lambert_Conformal_Conic'],PARAMETER['False_Easting',500000.0],PARAMETER['False_Northing',100000.0],PARAMETER['Central_Meridian',-93.38333333333334],PARAMETER['Standard_Parallel_1',44.88333333333333],PARAMETER['Standard_Parallel_2',45.13333333333333],PARAMETER['Latitude_Of_Origin',44.79111111111111],UNIT['Foot_US',0.304800609601219]]"
dont_list = [] #['1tin_v8.dgn', '2tin_v8.dgn', '10tin_v8.dgn', '11tin_v8.dgn', '12tin_v8.dgn', '13tin_v8.dgn', '14tin_v8.dgn', '15tin_v8.dgn', '16tin_v8.dgn', '17tin_v8.dgn', '18tin_v8.dgn', '19tin_v8.dgn', '20tin_v8.dgn', '21tin_v8.dgn', '22tin_v8.dgn', '23tin_v8.dgn', '24tin_v8.dgn', '25tin_v8.dgn', '26tin_v8.dgn', '27tin_v8.dgn', '28tin_v8.dgn', '29tin_v8.dgn', '30tin_v8.dgn', '31tin_v8.dgn', '32tin_v8.dgn', '33tin_v8.dgn', '34tin_v8.dgn', '35tin_v8.dgn', '36tin_v8.dgn', '37tin_v8.dgn', '38tin_v8.dgn', '3tin_v8.dgn', '40tin_v8.dgn', '41tin_v8.dgn', '46tin_v8.dgn', '4tin_v8.dgn']
logfile = output_folder + "\\DGNTIN_to_raster_log.txt"
bail = False
# Functions
def scan_dir(folder, filetype = "dgn", subdir = False):
'''scans a directory for files of a specific extension and returns them in a list'''
file_names = []
ext_len = len(filetype)
items = os.listdir(folder)
for item in items:
if item[- (ext_len + 1):] == "." + filetype:
file_names.append(item)
for item in file_names:
print item
f.write(item)
f.write("\n")
return file_names
def DGN_to_GDB(DGN_name, DGN_workspace, out_workspace):
'''Takes a TIN in Microstation DGN format and creates a GDB
by using the Data Interoperability Quick Import
This also assumes that you can correctly identify the correct parameters for the
Quick Import tool (possibly by creating a Model Builder model and exporting to
Python)'''
f.write("\n\n PROCESSING ")
f.write(str(DGN_name))
DGN_path = DGN_workspace + "\\" + DGN_name
print "\n PROCESSING ", DGN_path
parameter = []
parameter.append('''DGNV8,''')
parameter.append(DGN_path)
parameter.append(''',"RUNTIME_MACROS,""METAFILE,dgnv8,_XPNDCELL,YES,_PRESERVE_INSERTS,NO,EXPAND_UNNAMED_CELLS,NO,PRESERVE_UNNAMEDCELL_INSERTS,NO,SPLIT_MULTITEXT,YES,_TEXTTAGS,NO,EXPLODE_DIMENSION_ELEM,YES,_DROP_COMPLEX,NO,READ_XREF_FILES,NO,USE_XREF_PARENT_MODEL,NO,READ_XREF_UPTO_FIRST_LVL,NO,_IGDS_MSLINKS,NO,_IGDS_FRAMME,NO,_IN_UNITS,IGDS_MASTER_UNITS,OVERRIDE_GLOBAL_ORIGIN,NO,_UOR_GLOBAL_ORIGIN_X,,_UOR_GLOBAL_ORIGIN_Y,,APPLY_WORLD_FILE,YES,_MERGE_SCHEMAS,YES"",META_MACROS,""SourceMETAFILE,dgnv8,Source_XPNDCELL,YES,Source_PRESERVE_INSERTS,NO,SourceEXPAND_UNNAMED_CELLS,NO,SourcePRESERVE_UNNAMEDCELL_INSERTS,NO,SourceSPLIT_MULTITEXT,YES,Source_TEXTTAGS,NO,SourceEXPLODE_DIMENSION_ELEM,YES,Source_DROP_COMPLEX,NO,SourceREAD_XREF_FILES,NO,SourceUSE_XREF_PARENT_MODEL,NO,SourceREAD_XREF_UPTO_FIRST_LVL,NO,Source_IGDS_MSLINKS,NO,Source_IGDS_FRAMME,NO,Source_IN_UNITS,IGDS_MASTER_UNITS,SourceOVERRIDE_GLOBAL_ORIGIN,NO,Source_UOR_GLOBAL_ORIGIN_X,,Source_UOR_GLOBAL_ORIGIN_Y,,SourceAPPLY_WORLD_FILE,YES"",METAFILE,dgnv8,COORDSYS,""""""ESRIWKT|HENNEPIN COUNTY|PROJCS[""""HENNEPIN COUNTY"""",GEOGCS[""""GCS_User_Defined"""",DATUM[""""D_User_Defined"""",SPHEROID[""""User_Defined_Spheroid"""",6378418.941,298.2572242549207]],PRIMEM[""""Greenwich"""",0.0],UNIT[""""Degree"""",0.0174532925199433]],PROJECTION[""""Lambert_Conformal_Conic""""],PARAMETER[""""False_Easting"""",500000.0],PARAMETER[""""False_Northing"""",100000.0],PARAMETER[""""Central_Meridian"""",-93.38333333333334],PARAMETER[""""Standard_Parallel_1"""",44.88333333333333],PARAMETER[""""Standard_Parallel_2"""",45.13333333333333],PARAMETER[""""Latitude_Of_Origin"""",44.79111111111111],UNIT[""""Foot_US"""",0.304800609601219]]"""""",IDLIST,,__FME_DATASET_IS_SOURCE__,true"''')
parameters = '''"'''.join(parameter)
f.write("\n")
f.write(str(parameters))
new_GDB_name = DGN_name[3:5] + ".gdb"
new_GDB_path = out_workspace + "\\" + new_GDB_name
print "new GDB path = ", new_GDB_path
f.write("\n")
f.write(str(new_GDB_path))
## if not arcpy.Exists(new_GDB_path):
try:
arcpy.QuickImport_interop(parameters, new_GDB_path)
print arcpy.GetMessages()
f.write("\n")
f.write(str(arcpy.GetMessages()))
f.write("\n")
except:
f.write("\n")
f.write("\n")
if bail: sys.exit()
return new_GDB_name
def GDB_to_TIN(GDB_name, GDB_workspace, out_workspace):
'''Takes a GDB and uses all of the polygon feature classes with Z values
to create a new ESRI TIN'''
GDB_path = GDB_workspace + "\\" + GDB_name
print "\n\n GDB path = ", GDB_path
arcpy.env.workspace = GDB_path
FCs = arcpy.ListFeatureClasses()
print "FCs = ", FCs
FC_params = []
for FC in FCs:
FC_path = GDB_path + "\\" + FC
print "FC path = ", FC_path
desc = arcpy.Describe(FC_path)
## if desc.HasZ:
FC_params.append("'" + FC_path + "' Shape.Z hardline <None>")
print "\n FC params = ", FC_params
params = ";".join(FC_params)
print params
f.write("\n")
f.write(params)
f.write("\n")
new_TIN_name = "TIN_" + GDB_name[:2]
new_TIN_path = out_workspace + "\\" + new_TIN_name
try:
arcpy.CreateTin_3d(new_TIN_path, "", params, "CONSTRAINED_DELAUNAY")
f.write("\n")
f.write("\n")
try:
time.sleep(30)
arcpy.Delete_management(GDB_path, "")
f.write("\n")
f.write("\n")
except:
f.write("\n")
f.write("\n")
if bail: sys.exit()
except:
f.write("\n")
f.write("\n")
if bail: sys.exit()
return new_TIN_name
def TIN_to_raster(TIN_name, TIN_workspace, out_workspace):
'''Converts an ESRI TIN to raster'''
TIN_path = TIN_workspace + "\\" + TIN_name
raster_name = TIN_name[4:6]
raster_path = out_workspace + "\\" + raster_name
try:
print TIN_path
print raster_path
arcpy.TinRaster_3d(TIN_path, raster_path, "FLOAT", "LINEAR", "CELLSIZE 5", "1")
f.write("\n")
f.write(arcpy.GetMessages())
f.write("\n")
try:
arcpy.Delete_management(TIN_path, "")
except:
if bail: sys.exit()
except:
f.write("\n")
f.write("\n")
if bail: sys.exit()
def main():
DGN_list = scan_dir(DGN_folder, "dgn")
for TIN in DGN_list:
if TIN not in dont_list:
new_GDB = DGN_to_GDB(TIN, DGN_folder, output_folder)
new_TIN = GDB_to_TIN(new_GDB, output_folder, output_folder)
TIN_to_raster(new_TIN, output_folder, output_folder)
# Body
start_time = time.clock()
f = open(logfile, 'w')
main()
f.close()
print
print "*" * 80
stop_time = time.clock()
elapsed_time = stop_time - start_time
print "Start Time: ", start_time
print "Stop Time: ", stop_time
print "Elapsed time = " + str(round(elapsed_time / 60, 1)) + " minutes"
print "*" * 80
good luck!
