Solved! Go to Solution.
My work around i think should be to have the infoWindow display when a user double clicks.
The problem is that if I click the measure widgit and then click the map, it not only starts measureing, but it also displayes the infoWindow.
var clickListener = dojo.connect(map, "onClick", myClickHandler); dojo.disconnect(clickListener);
