ModelBuilder & Query tool help
776
06-25-2011 01:37 PM
AudreyNavarro1
Is scripting necessary?
I am really not sure what kind tool to develop that will process a batch of queries but I more so want to create something that will be easy for a beginner user (of ArcGIS) to easily run; the individual is look to query some data (periodically throughout the year) in a plant inventory feature class within a file gdb. and possibly run reports of the queried data.
For example:
  • What plants have died?
  • Where are a specific plant species located?
  • What plants are in a specific area boundary?
Can you create several different models (for each of the queries) in ModelBuilder that he may run?  Or utilizing the tool 'create a query table' to run his queries? What would be the best approach?
Thank you!
MarkEnglish
If your queries don't change, and you will re-run the same queries throughout the year, I would simply build one or multiple models that can automate the process.
DuncanHornby
MVP Notable Contributor
To compliment Mark English you could create a toolbox. Create several models, 1 for each type of query, expose the inputs/outputs as parameters and then document these through it's metadata. You will then have created a toolbox with several Model Tools that have the familiar look and feel of any other geo-processing tool.
Turning an existing model into a tool is fairly trivial, it's the fine tweaking that makes all the difference to the use experience.
