Extract one band from 3 band raster
10529
5
06-27-2011 09:59 AM
StephanieSnider
Occasional Contributor III
ArcGIS 10 SP2, Windows XP
I know there must be a simple solution to this, but I haven't found it yet.  Is there a way to extract one band from a 3-band raster and output that to a new one-band raster dataset?  I see there is a tool for composite bands, for making several rasters into one raster.  But how to you go the other direction?
RobertBerger
New Contributor III
Greetings,
Yes, the composite bands tool will accomplish this. You can drill into the raster and input the desired band to the tool.
Robert
StephanieSnider
Oh, I see.  You have to select the band within the raster and not the raster itself.  Got it.  I can use the copy Raster tool.  Thanks!
StephanieSnider
In case anyone needs to do this in batch mode like myself, here's some python to help:
# Import arcpy module
import arcpy
origin = "E:\\SDEstage\\Unloaded\\3-band\\"
arcpy.env.workspace = origin
RasterList = arcpy.ListRasters()
RasterList2 = []
# Remove the ".tif" in order to create raster name that will store in FGD
for x in range(len(RasterList)):
    [INDENT]RasterList2 = RasterList2 + [RasterList[:-4]][/INDENT]
for i in range(len(RasterList2)):
    [INDENT]# Set Tif and Band #
    TiftoLoad = origin + RasterList2 + ".tif\\Band_1"
    # Since these tif file names begin with a number, add letter to beginning in order to store in FGD.
    dest = "E:\\SDEstage\\Rasters.gdb\\A" + RasterList2
    # Copy raster
    arcpy.CopyRaster_management(TiftoLoad, dest, "", "", "", "NONE", "NONE", "")
    print "Converted " + RasterList2[/INDENT]
ScottRoberts
How do you select the band within the raster and not the raster itself?
FionaGregory
Here's one way:
In ArcCatalog - Contents tab - click on the name of the raster and it will drill down to the individual bands. Drag each band from ArcCatalog into the Composite Bands tool.
