GDB files used in this code are attached to this post; see my blog pythongisandstuff.wordpress.com, which goes into greater detail about the methods for developing normal scripts into scripts suitable for Multiprocessing...'''
Step 4 of 4: Example of using Multiprocessing/Parallel Python with Arcpy...
Can be run either:
1. from the command line/a Python IDE (adjust paths to feature classes, as necessary)
2. as a Script tool within ArcGIS (ensure 'Run Ptyhon script in Process' is NOT checked when importing)
The Parallel Python library must be installed before it can be used.
import arcpy
import multiprocessing
import time
try:
import pp
forceMP = False
except ImportError:
forceMP = True
def performCalculation(points_fC, polygons_fC, searchDist, typeList, calcPlatform_input=None):
'''performCalculation(pointsFeatureClass, polygonsFeatureClass, searchDistance, typeList, calcPlatform)
All inputs are specific.
calcPlatform is either 'mp', to use the inbuilt Multiprocessing library, or 'pp', to use Parallel Python (if it exists, otherwise defaults to mp)
## Pre-calculation checks
# Check calculation platform is valid, or resort to default...
defaultCalcTpye = 'mp'
calcTypeExplainDict = {'pp':'Parallel Python', 'mp':'Multiprocessing'}
if forceMP: # unable to import Parallel Python library (it has to be installed seperately)
arcpy.AddMessage(" WARNING: Cannot load Parallel Python library, forcing Multiprocessing library...")
calcPlatform = 'mp'
elif (calcPlatform_input not in ['mp', 'pp']) or (calcPlatform_input == None): # Invalid/no input, resort to default
arcpy.AddMessage(" WARNING: Input calculation platform '%s' invalid; should be either 'mp' or 'pp'. Defaulting to %s..." % (calcPlatform_input, calcTypeExplainDict[defaultCalcTpye]))
calcPlatform = defaultCalcTpye
else:
calcPlatform = calcPlatform_input
## Data extraction (parallel execution)
searchDist = int(searchDist) # convert search distance to integer...
# check all datasets are OK; if not, provide some useful output and terminate
valid_points = arcpy.Exists(points_fC)
arcpy.AddMessage("Points Feature Class: "+points_fC)
valid_polygons = arcpy.Exists(polygons_fC)
arcpy.AddMessage("Polygons Feature Class: "+polygons_fC)
dataCheck = valid_points & valid_polygons
if not dataCheck:
if not valid_points:
arcpy.AddError("Points database or feature class, %s, is invalid..." % (points_fC))
if not valid_polygons:
arcpy.AddError("Polygons database or feature class, %s, is invalid..." % (polygons_fC))
else: # Inputs are OK, start calculation...
for type in typeList: # add fields to Points file
arcpy.AddField_management(points_fC, "polygon_type%s_Sum" % type, "DOUBLE")
arcpy.CalculateField_management(points_fC, "polygon_type%s_Sum" % type, 0, "PYTHON")
arcpy.AddField_management(points_fC, "polygon_type%s_Count" % type, "DOUBLE")
arcpy.CalculateField_management(points_fC, "polygon_type%s_Count" % type, 0, "PYTHON")
arcpy.AddMessage(" Added polygon_type%s_Sum and polygon_type%s_Count fields to Points." % (type,type))
pointsDataDict = {} # dictionary: pointsDataDict[pointID][Type]=[sum of Polygon type weightings, count of Ploygons of type]
jobs = [] # jobs are added to the list, then processed in parallel by the available workers (CPUs)
if calcPlatform == 'mp':
arcpy.AddMessage(" Utilising Python Multiprocessing library:")
pool = multiprocessing.Pool() # initate the processing pool - use all available resources
# pool = multiprocessing.Pool(2) # Example: limit the processing pool to 2 CPUs...
for type in typeList: # For this specific example
arcpy.AddMessage(" Passing %s to processing pool..." % type)
jobs.append(pool.apply_async(findPolygons, (points_fC, polygons_fC, type, searchDist))) # send jobs to be processed
for job in jobs: # collect results from the job server (waits until all the processing is complete)
if len(pointsDataDict.keys()) == 0: # first output becomes the new dictionary
pointsDataDict.update(job.get())
else:
for key in job.get(): # later outputs should be added per key...
pointsDataDict[key].update(job.get()[key])
del jobs
elif calcPlatform == 'pp':
ppservers=()
job_server = pp.Server(ppservers=ppservers) # initate the job server - use all available resources
# job_server = pp.Server(2, ppservers=ppservers) # Example: limit the processing pool to 2 CPUs...
arcpy.AddMessage(" Utilising Parallel Python library:")
for type in typeList: # For this specific example, it would only initate three processes anyway...
jobs.append(job_server.submit(findPolygons, (points_fC, polygons_fC, type, searchDist), (), ("arcpy",))) # send jobs to be processed
if len(pointsDataDict.keys()) == 0: # first output becomes the new dictioanry
pointsDataDict.update(job())
else:
for key in job():
pointsDataDict[key].update(job()[key]) # later outputs should be added per key...
del jobs
## Writing data back to points file
arcpy.AddMessage(" Values extracted; writing results to Points...")
pointsRowList = arcpy.UpdateCursor(points_fC)
for pointsRow in pointsRowList: # write the values for every point
pointID = pointsRow.getValue("PointID")
pointsRow.setValue("polygon_type%s_Sum" % type, pointsRow.getValue("polygon_type%s_Sum" % type) + pointsDataDict[pointID][type][0])
pointsRow.setValue("polygon_type%s_Count" % type, pointsRow.getValue("polygon_type%s_Count" % type) + pointsDataDict[pointID][type][1])
pointsRowList.updateRow(pointsRow)
del pointsRow
del pointsRowList
# just make sure any locks are cleared...
del calcPlatform, calcPlatform_input, calcTypeExplainDict, dataCheck, defaultCalcTpye, job, key, pointID, pointsDataDict, points_fC, polygons_fC, type, valid_points, valid_polygons, searchDist, typeList
def findPolygons(points_FC, polygons_FC, Type, search_dist):
funcTempDict = {}
arcpy.MakeFeatureLayer_management(polygons_FC, '%s_%s' % (polygons_FC, Type))
arcpy.MakeFeatureLayer_management(points_FC, '%s_%s' % (points_FC, Type))
pointsRowList = arcpy.SearchCursor('%s_%s' % (points_FC, Type))
for pointRow in pointsRowList: # for every origin
pointID = pointRow.getValue("PointID")
try:
funcTempDict[pointID][Type] = [0,0]
except KeyError: # first time within row
funcTempDict[pointID] = {}
arcpy.SelectLayerByAttribute_management('%s_%s' % (points_FC, Type), 'NEW_SELECTION', '"PointID" = \'%s\'' % pointID)
arcpy.SelectLayerByLocation_management('%s_%s' % (polygons_FC, Type), 'INTERSECT', '%s_%s' % (points_FC, Type), search_dist, 'NEW_SELECTION')
arcpy.SelectLayerByAttribute_management('%s_%s' % (polygons_FC, Type), 'SUBSET_SELECTION', '"polyType" = %s' % Type)
polygonsRowList = arcpy.SearchCursor('%s_%s' % (polygons_FC, Type))
for polygonsRow in polygonsRowList:
funcTempDict[pointID][Type][0] += polygonsRow.getValue("polyWeighting")
funcTempDict[pointID][Type][1] += 1
return funcTempDict
if __name__ == '__main__':
# Read the parameter values:
# 1: points feature class (string to location, e.g. c:\GIS\Data\points.gdb\points01)
# 2: polygons feature class (string to location)
# 3: search distance for polygons, integer, e.g 500
# 4: calculation type ('mp' to use Multiprocessing library, 'pp' to use Parallel Python library (if available, otherwise defaults to mp))
pointsFC = arcpy.GetParameterAsText(0) # required
polygonsFC = arcpy.GetParameterAsText(1) # required
search_Distance = arcpy.GetParameterAsText(2) # required
calcType = arcpy.GetParameterAsText(3) # optional (will default to MP)
t_start = time.clock()
type_list = [1,2,3,4,5,6] # polygon types to search for...
# run calculation
if '' in [pointsFC, polygonsFC, search_Distance]:# if not running from Arc, the input parameters all come out as ''
pointsFC = "c:\\Work\\GIS\\Data\\Points.gdb\\points01"
polygonsFC = "c:\\Work\\GIS\\Data\\Polygons.gdb\\polygons01"
search_Distance = 1000
performCalculation(pointsFC, polygonsFC, search_Distance, type_list)
else:
performCalculation(pointsFC, polygonsFC, search_Distance, type_list, calcType)
arcpy.AddMessage(" ... complete in %s seconds." % (time.clock() - t_start))
