Making fields hidden/visible using MakeFeatureLayer help
8602
9
06-29-2011 02:53 AM
HalilSiddique
Occasional Contributor II
Hi all,
I have an SDE layer, that I am using in my script, that becomes a Feature layer (to be used later in my script). Of the fields within the feature class, I only need a few, and I have reflected this in the script but it still appears to keep all the fields.
# Create Feature Layer from BLPU point
    gp.makeFeatureLayer_management(inputPoint, "point_lyr", "", "","UPRN UPRN VISIBLE; ADDRESS ADDRESS VISIBLE")
    print "1 - ", inputPoint, "is now a feature layer"
    # Export Joined Point layer
    gp.copyFeatures_management("point_lyr", "READY_FOR_SDE_test")
    print "14 - ", "Joined points has been exported to", datadump
Any ideas on how to get this working?
Cheers
Halil
ChrisSnyder
Regular Contributor III
Here is some code that does a similar thing... been working great for years...
fieldInfo = ""
fieldList = gp.listfields(layerPath)
for field in fieldList:
    if field.name == "PARCEL_SYST_ID":
        fieldInfo = fieldInfo + field.Name + " " + "PARCEL_ID" + " VISIBLE;"
    elif field.name == "SURFACE_TRUST_CD":
        fieldInfo = fieldInfo + field.Name + " " + "SUR_OWN_CD" + " VISIBLE;"
    elif field.name == "SURFACE_TRUST_NM":
        fieldInfo = fieldInfo + field.Name + " " + "SUR_OWN_NM" + " VISIBLE;"
    elif field.name == "TIMBER_TRUST_CD":
        fieldInfo = fieldInfo + field.Name + " " + "TIM_OWN_CD" + " VISIBLE;"
    elif field.name == "TIMBER_TRUST_NM":
        fieldInfo = fieldInfo + field.Name + " " + "TIM_OWN_NM" + " VISIBLE;"
    else:
        fieldInfo = fieldInfo + field.Name + " " + field.Name + " HIDDEN;"
gp.MakeFeatureLayer_management(layerPath, "feature_layer", "", "", fieldInfo[:-1]); showGpMessage()
gp.MultipartToSinglepart_management("feature_layer", fgdbPath + "\\" + layerName); showGpMessage()
ChrisSnyder
The issue you are having is that you need to list EVERY field in the table and indicate "ORIGINAL_NAME NEW_NAME HIDDEN/VISIBLE"
Maybe something like this:
keepFieldList = ("FIELD1","FIELD2")
fieldInfo = ""
    if field.name in keepFieldList:
        fieldInfo = fieldInfo + field.Name + " " + field.name + " VISIBLE;"
    else:
MarcusSilva1
Hi All,
What's the use of fieldinfo's method "setVisible (index, visible)" worth for? It seems it doesn't work or I'm doing something wrong.  I'm trying to use
        while index < fieldInfo.count:
            arcpy.AddMessage(fieldInfo.GetVisible(index))
            fieldInfo.setVisible(index, "HIDDEN")
            arcpy.AddMessage('fieldInfo.GetVisible(index))
            index += 1
in my python script but nothing happens. Any ideas?
Marcus
ChrisSnyder
I also couldn't get the fieldInfo() methods to work... For example:
>>> fc = r"C:\csny490\test.gdb\haul_routes_lt_flat_l_1_3"
>>> arcpy.MakeFeatureLayer_management(fc,"fl")
>>> dsc = arcpy.Describe("fl")
>>> dsc.FieldInfo.exportToString ()
u'OBJECTID OBJECTID VISIBLE NONE;Shape Shape VISIBLE NONE;FacilityID FacilityID VISIBLE NONE;ALTERNATIVE ALTERNATIVE VISIBLE NONE;DECADE DECADE VISIBLE NONE;SPATIAL_ID SPATIAL_ID VISIBLE NONE;MBF MBF VISIBLE NONE;Shape_Length Shape_Length VISIBLE NONE'
>>> dsc.FieldInfo.setFieldName(3, "ALT") #This should rename ALTERANTIVE to ALT
>>> dsc.FieldInfo.setVisible(4, "HIDDEN") #This should make DECADE to HIDDEN
>>> arcpy.CopyFeatures_management("fl",r"C:\csny490\test.gdb\test333")
<Result 'C:\\csny490\\test.gdb\\test333'>
The changes I made to the feature layer were also not reflected when I exported it out to a FeatureClass (test333).
Hmmm... I must be missing something here too.
I'll bet it still works if you build a proper text sting and feed it into the MakeFeatureLayer tool.
ChrisSnyder
curtvprice
MVP Esteemed Contributor
In your code example you are trying to modify a read-only describe object, not the layer the describe object was created from.
I think the most straighforward way would be to create a new layer with MakeFeatureLayer, setting the field properties in the arguments.
A less straightforward way would be to dive into arcpy.mapping's layer object. (Suggestions from arcpy.mapping mavens to this thread are welcome!)
ChrisSnyder
I would think the set*() methods under fieldInfo() are meant to be writeable.... The get*() methods of course are read only...
From the documentation:
setFieldName (index, field_name): Sets the field name into the table.
setNewName (index, new_field_name): Sets the new field name into the table.
setSplitRule (index, rule): Sets the split rule into the table.
setVisible (index, visible): Set the visible flag of a field on the table.
KellyWhitehead
I've been having similar frustrations with FieldInfo in my script as well. I ran a quick test in the python window:
>>> test = arcpy.FieldInfo()
>>> test.addField("Name","NewName","VISIBLE","NONE")
>>> test.setVisible(0,"HIDDEN")
>>> test.getVisible(0)
u'VISIBLE'
>>> test.getSplitRule(0)
u'HIDDEN'
The setVisible method appears to be changing the SplitRule instead.
Looks like a bug to me...
kevindevine
This is what I used to get this working from the examples above.  After modifying the fieldInfo for the previously created memorynet feature layer, I created another feature layer from that and then used the "in_memory//" to create yet another layer which had the correctly modified fields.
keepFieldList = ("Field1","Field2", "Field3", "Field4", "Field5")
fieldInfo = ""
fieldList = gp.listfields(memorynet)
 print field.name
 else:
print fieldInfo
gp.MakeFeatureLayer_management(memorynet, "feature_layer", "", "", fieldInfo[:-1])
memfldNet = "in_memory//memfldNet"
arcpy.CopyFeatures_management("feature_layer", memfldNet)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
