Mr_Kirkwood
Embed video code not working in ARC for HTML PopUp tool
Discussion created by Mr_Kirkwood on Apr 5, 2010
I am having trouble with the XSL template and some simple code. I cannot get the video to show up in the HTML popup window inside arc using the template or using a simple code. I have a simple point feature. The feature has a column named VIDEO with a link in the attribute table "http://www.youtube.com/watch?v=1pkUFKKhAZM"
here is the simple code
<?xml version="1.0" encoding="UTF-8"?>
<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:fo="http://www.w3.org/1999/XSL/Format">
<xsl:template match="/">
<html>
<body>
  <xsl:variable name="nameCol" select="FieldsDoc/Fields/Field/FieldName"/>
  <table border="1" width="300" cellpadding="5" cellspacing="0">
  <xsl:variable name="index" select="1"/>
  <xsl:for-each select="FieldsDoc/Fields/Field">
  <xsl:if test="FieldName[starts-with(., 'VIDEO')]">
  <xsl:attribute name="bgcolor">#5757FF</xsl:attribute>
<tr>
  <xsl:if test="(position() +1) mod 2">
  </xsl:if>
<td>
<xsl:choose>
  <xsl:when test="FieldName[starts-with(., 'VIDEO')]">
  <xsl:variable name="videoURL" select="FieldValue"/>
<object>
  <param name="movie" value="{$videoURL}" wmode="transparent" ></param>
  <embed src="{$videoURL}" type="application/x-shockwave-flash"  width="480" height="385"></embed>
</object>
  </xsl:when>
</xsl:choose>
</td>
</tr>
</xsl:if>
</xsl:for-each>
</table>
</body>
</html>
</xsl:template>
</xsl:stylesheet>
The other code can be found in at C:\Program Files\ArcGIS\Styles\HTMLPopup\EmbedVideo.xsl
any ideas?
Outcomes
