Polygon ZM
10632
07-08-2011 12:14 PM
SpencerLarson
New Contributor III
I have a shapefile and everytime I export it out by selecting a feature it outputs a Polygon ZM  attributewhich I understand it has a property for Z values.  I need it to export out with out this Polygon ZM just a regular shapefile as  Polygon.  I am trying to upload the shapefile to a online web application but it gives me the error message that the shapefile can't have a Z value.  Any solutions?
Spencer Larson
EricBuehler
I know this is a really old thread, but I just ran into this same issue today and I thought my comments may be of help to someone in the future.  I ended up going into the environment settings to get rid of the Z and M values.  I used the Feature To Polygon (Data Management) tool.  Then in the Environments settings of the tool I set the M Values to "Disabled" and I also set the Z Values to "Disabled".
As a side note I recommend using the feature to point tool first to get the attributes into a point feature class.  Then in the Feature to Polygon tool, you can add the point feature class in the "Label Features" section.  This makes it so the new polygon feature class still has all of the correct attributes as well as being a plain polygon without Z or M values.
Tags (3)
KateRose
New Contributor III
Years later, and this worked for me (in ArcPro 2.9) - thanks!
