Modify Icon SIZE of Widget that is diaplayed in the Header Controller
5778
9
07-13-2011 04:04 PM
SallyGracia
I received a request to make the Icons/PNG's for the widgets larger in the Header. I made the PNG's larger and replaced them and they are displaying in my viewer the same size. Cleared the cache and so forth.
Makes me think the Icon/Image in controlled in a default.css or skin??
All assistance is greatly appreciated.
RobertScheitlin__GISP
Sally,
   The GroupWidgetItemDataGroupRenderer.mxml has the width of the icon set to 25px in the code:
<mx:Image id="icon"
                  width="25" height="100%"
                  buttonMode="true"
                  smoothBitmapContent="true"
                  useHandCursor="true"/>
SallyGracia
Hi Robert,
Thank You for your help, its warm 🙂  getting closer.  Im going just search for that image. The code recommended to modify changed the Icon Image in the Open state of the widget. I attached a print screen of what changed.
Sally,
   Well it will take changes to several location.
//HeaderControllerWidget.mxml
<s:Group id="headerGroup"
             width="100%" height="105">
//GroupWidgetItemDataGroupRender.mxml
 <s:VGroup width="45" height="50"
              gap="2"
              horizontalAlign="center"
              rollOut="mouseOutHandler(event)"
              rollOver="mouseOverHandler(event)"
              verticalAlign="middle">
        <mx:Image id="icon"
                  width="45" height="100%"
                  buttonMode="true"
//WidgetItemDataGroupRender.mxml
              gap="2"
        <mx:Image id="icon"
                  buttonMode="true"
                  mouseOut="mouseOutHandler(event)"
                  mouseOver="mouseOverHandler(event)"
//WidgetListItemRenderer.mxml
<s:HGroup width="100%" height="50"
                  buttonMode="true"
                  paddingLeft="10"
                      horizontalAlign="center">
//HeaderGroup.mxml
<s:SkinnableContainer xmlns:fx="http://ns.adobe.com/mxml/2009"
                      xmlns:s="library://ns.adobe.com/flex/spark"
</s:SkinnableContainer>
GabiVoicu1
New Contributor III
I'm trying to do the same exact thing but I can't seem to find those mxml files - perhaps the webappbuilder version changed and they have also changed names, locations etc or where should I look for those files at version 2.0 or higher?
Thank you
Gabi,
   Nope in 3.7 those files are still the same. You need to be sure to use the un-compiled developer version of Flex Viewer so you have access to the mxml file and not just the compiled swf files. You also really need to move to a product that is still supported by esri unlike the ArcGIS Viewer for Flex.
GabiVoicu1
New Contributor III
Ooops….. Robert thank you so very much for replying – you’re the best!
I was in the wrong discussion forum I believe…… I was actually looking to do the same thing but for the for the web appbuilder I’m trying to change the icon size for the webappbuilder add text instead of icons for example and for that we may need to adjust to witdh of the icon to accommodate the text!
Gabi Voicu, GISP
Sr GIS Analyst
IT/GIS City of Grand Prairie
317 College St. TX 75050
97°0’21.64”W, 32°44’49.92” N
Phone: 972-237-8324
Fax: 972-237-8161
email:gvoicu@gptx.org
Gabi,
   You should do a search for that in the WAB spaces then as I have answered those questions in the past.
GabiVoicu1
New Contributor III
Yes, yes, yes I found it thank you so very much…..
Gabi Voicu, GISP
Sr GIS Analyst
Phone: 972-237-8324
Fax: 972-237-8161
GabiVoicu1
New Contributor III
Robert, I did find this thread where you answered before
https://community.esri.com/message/646171-re-increase-icon-size?commentID=646171#comment-646171
…….and did change the width and size for the icons but now I’m still in serach for these twp pasted here below…..where do I go for those?!???
Thank you
Gabi Voicu, GISP
Sr GIS Analyst
Phone: 972-237-8324
Fax: 972-237-8161
