Hi everyone,I have a standalone C# application that contains the following procedure which gets called to find a particular feature within an array of layers. This procedure gets called numerous times from inside a loop. Everything works fine for the first 25 passes but on the 26th pass, I get an error of "ORA-01000: maximum open cursors exceeded" on line pFeatureClass = pFeatureWorkspace.OpenFeatureClass(permitType).No matter where I try to do marshall release to free up the com objects, I keep getting the error. Been fighting with this for almost a day now and I'm out of ideas.Any insights are GREATLY appreciated!Carlos internal static void FindApplication(string appNo, out IFeature pOutFeature, out IFeatureClass pOutFeatureClass)
IPropertySet pPropertySet = new PropertySetClass();
IWorkspaceFactory pWorkspaceFactory = new SdeWorkspaceFactoryClass();
IFeatureWorkspace pFeatureWorkspace = null;
IFeatureClass pFeatureClass = null;
IQueryFilter pQueryFilter = new QueryFilterClass();
IFeatureCursor pFeatureCursor = null;
IFeature pFeature = null;
pOutFeature = null;
pOutFeatureClass = null;
string permitType = string.Empty;
try
pPropertySet.SetProperty("Server", "gerrdsde");
pPropertySet.SetProperty("Instance", "5154");
pPropertySet.SetProperty("Database", "gerrd");
pPropertySet.SetProperty("User", "rim");
pPropertySet.SetProperty("Password", "RPS4240sde");
pPropertySet.SetProperty("Version", "SDE.DEFAULT");
string[] layerArray = {"RIM.PRSTF_JDS_APP_AREA", "RIM.PRSTF_SBL_APP_AREA", "RIM.PRSTF_OST_APP_AREA",
"RIM.PRSTF_DAF_APP_AREA", "RIM.PRSTF_AQU_APP_AREA", "RIM.PRSTF_WDI_APP_AREA",
"RIM.PRSTF_MIT_APP_AREA", "RIM.PRSTF_WDF_APP_AREA", "RIM.PRSTF_WUP_PWS_APP_AREA",
"RIM.PRSTF_WUP_DEW_APP_AREA", "RIM.PRSTF_WUP_DIV_APP_AREA", "RIM.PRSTF_WUP_APP_AREA",
"RIM.PRSTF_SWM_APP_AREA", "RIM.PRSTF_ERP_APP_AREA", "RIM.PRSTF_LOK_APP_AREA",
"RIM.PRSTF_WQE_AREA"};
for (int i = 0; i < layerArray.Length; i++)
permitType = layerArray;
pFeatureWorkspace = pWorkspaceFactory.Open(pPropertySet, 0) as IFeatureWorkspace;
pFeatureClass = pFeatureWorkspace.OpenFeatureClass(permitType);
pQueryFilter = new QueryFilter();
pQueryFilter.WhereClause = "APP_NO = '" + appNo + "'";
pFeatureCursor = pFeatureClass.Search(pQueryFilter, false);
pFeature = pFeatureCursor.NextFeature();
if (pFeature != null) break;
//If feature found, return feature and feature class feature is in.
if (pFeature != null && pFeatureClass != null)
pOutFeature = pFeature;
pOutFeatureClass = pFeatureClass;
catch (Exception ex)
MessageBox.Show("Procedure FindApplication " + ex.Message);
finally
if (pQueryFilter != null) { Marshal.ReleaseComObject(pQueryFilter); pQueryFilter = null; }
if (pFeatureCursor != null) { Marshal.ReleaseComObject(pFeatureCursor); pFeatureCursor = null; }
if (pPropertySet != null) { Marshal.ReleaseComObject(pPropertySet); pPropertySet = null; }
if (pWorkspaceFactory != null) { Marshal.ReleaseComObject(pWorkspaceFactory); pWorkspaceFactory = null; }
if (pFeatureWorkspace != null) { Marshal.ReleaseComObject(pFeatureWorkspace); pFeatureWorkspace = null; }
permitType = null;
