GPS Analyst toolbar missing "Get Data for ArcPad" buttons
3377
07-29-2011 11:28 AM
RickCarter
I recently installed ArcMap 10 and GPS Analyst 2.3. Also running ArcPad 8.0 SP2. When I activate the Trimble GPS Analyst toolbar, the check in and out buttons "Get Data for ArcPad" do not show up. The only check in and out buttons that show up are for AXF.
Everything worked fine under 9.3, but not now. Any thoughts?
Tags (3)
BrettBlack1
I believe you need to be running ArcPad 10 in conjunction with ArcMap 10 in order to have access to the ArcPad Data Manager.
TimHopper
Occasional Contributor III
I'm not sure I'm following you 100%, but I'll give it a shot.
The work flow you're trying to use should be possible.
1. When you say that the "Get Data For ArcPad" buttons don't show up, is it that they're missing completely or are the icons grayed out?
The GPS Analyst toolbar v2.3 does not contain "Get Data For ArcPad" buttons like you would see on the ArcPad Data Manager toolbar.  To check in and out you must utilize the two AXF buttons on the right side of the toolbar.  When you hover over them they say "Get Data For ArcPad" and "Check in ArcPad AXF file and GPScorrect SSF".  These are essentially the same tools as you would see on the ArcPad Data Manager toolbar, except the check in process checks in the SSF to the geodatabase as well.
The ArcPad toolbar (the short three-icon toolbar) was deprecated at version 10.
Because of this, in ArcMap 10 you can no longer check out to shapefile as you could at version 9.3.1.  You must check the data out to axf for disconnected editing (which is the functionality that the ArcPad Data Manager toolbar utilizes).
2. If the buttons are grayed out, make sure that you've checked on both the ArcPad Data Manager and Trimble GPS Analyst extensions in the Customize Menu > Extensions list.
Hope this helps.
TimHopper
I should also mention:
Problem:  ArcPad Data Manager extension is not visible in ArcMap 10
http://support.esri.com/en/knowledgebase/techarticles/detail/38344
BethReynolds
I have recently upgraded to ArcGIS 10, formerly running 9.3.1 with Trimble GPS Analyst 2.2, two field techs running GeoXH 2008 with ArcPad 7.1.1. I upgraded the GPS Analyst to 2.3. I have also lost my "Get Data for ArcPad (AXF)" button(s). We have been accustomed to check in/outs with AXF format. Any advice on how to retrieve the button or has it been removed in the upgrade? If so, am I looking at an upgrade on the units as well? Not fond of ArcPad 8? Not sure if handhelds can handle ArcPad 10? Any advice would be gracious...thanks!
