"Database engine could not lock table...."
641
08-02-2011 06:48 AM
AlexGetchell
When attempting to move vertices with the edit tool after saving edits, an error pops up saying:
"Modify Feature: An unexpected failure occurred.
The database engine could not lock table 'DELTA_Parcels_SHAPE_Index'
because it is already in use by another person or process."
It will give the error for every other feature class in the geodatabase, as well.
This happens even when there are no other users "touching" the data and is in the ArcGIS 10 environment.
Has anyone else encountered this issue? Thoughts? Recommendations? Thanks!
DanielleCullen
I am having the same issue, did you figure out how to fix it?
