Python Field Calculate issue
Discussion created by brumm1dj on Aug 12, 2011
Latest reply on Aug 15, 2011 by brumm1dj
I am trying to use python inside of ArcMap to perform a field calculation. I am attempting to replace one word with another in my hyperlink field. My issue is that when I run the field calculator it replaces the words correctly, but it also changes the '\0' into little squares or question marks. I have tried using code blocks and writing the syntax differently but I keep getting the same result.
                       \\\\\\this is some example data\\\\\\\
\\gis1\GIS\Projects\Water\MidlandGTG\MidlandCity\Valves\Sec. 07\07-019.pdf
\\gis1\GIS\Projects\Water\MidlandGTG\MidlandCity\Valves\Sec. 07\07-020.pdf
\\gis1\GIS\Projects\Water\MidlandGTG\MidlandCity\Valves\Sec. 07\07-021.pdf
\\gis1\GIS\Projects\Water\MidlandGTG\MidlandCity\Valves\Sec. 07\07-022.pdf
\\gis1\GIS\Projects\Water\MidlandGTG\MidlandCity\Valves\Sec. 07\07707-002.pdf
!HYPERLINK!.replace("Projects","Data") //////this is the code I used//////
