Find layer geometry type
4911
13
08-15-2011 04:01 AM
BabbageOcelot
Hello all,
I may just be being dim on a Monday afternoon, but I can't seem to find any way of finding a layer's specified geometry type. This is shown in the REST endpoint as "Geometry Type: esriGeometryPoint"; unfortunately it doesn't seem to be exposed in either the Layer properties, or in the layerInfos object.
What I need to do is create a custom-symbolised featureLayer on the fly, and in order for that to work I need to know the geometry present in this particular layer.
Sadly, I can't use layerDefinitions (which would be far more appropriate).
Any ideas?
- Ben
HemingZhu
Occasional Contributor III
Hello all,
Any ideas?
- Ben
FeatureLayer.geometryType.
BabbageOcelot
Hi Heming,
thanks - turns out I am being dim on a Monday. Create the feature layer, *then* find the geometry type, symbolise accordingly.
It is a little strange that the type isn't accessible without first creating a featureLayer; I'd expect that to be in layerInfos[layerId], or similar.
Cheers,
Ben.
HemingZhu
Hi Heming,
Cheers,
Ben.
I agreed with you on that.
MichaelKyffin
Yes - I think being able to expose the geometry type of the (sub) layers could be useful for many, many reasons. I'm surprised this isn't in layerInfos, actually. It's a little silly to have to create a feature layer just to get at this.
MarkSmith
New Contributor III
Can you help me out please?  I've just been looking at this too but can't work out what I'm getting wrong.  I have the following lines to try and work out what the geometry type of a layer is, but my alert just give me 'undefined', can you please show me the correct way of getting this?
anFeatureLayer = new esri.layers.FeatureLayer("http://server/ArcGIS/rest/services/service/FeatureServer/0", {mode: esri.layers.FeatureLayer.MODE_SELECTION});
    geomType = anFeatureLayer.geometryType
    alert(geomType)
Thank you.
JayJohnson1
The reason it's not exposed is because not all layers are feature layers. Some layers are rasters.
MichaelKyffin
Agreed - but I wouldn't want to use feature layers at all, but rather the index of the "sub"layer inside a map service. Additionally, the geometryType of the feature layer isn't exposed until it's added to the map.
StephanieSnider
So what should I do if the geometry type is blank in the map service for a point layer?  I have some point layers that are set to "esriGeometryPoint", but others are just blank.  This causes a problem when trying to work with the ArcGIS Viewer for Silverlight.  I cannot use the layer because the geometry type is "unspecified".  How do I set the geometry type of an unspecified layer?
Here's an example of a point layer with an unspecified geometry type:
http://ndep-emap.nv.gov/ArcGIS/rest/services/eMap/MapServer/17
HemingZhu
That is causing your featureLayer's geometry being undefined (I tried featureLayer.graphics[0].geometry.type too). That is interesting!!
