psiclopz
Map Resolutions
Discussion created by psiclopz on Aug 15, 2011
Latest reply on Aug 18, 2011 by MBranscomb-esristaff
I want to set the MaximumResolution property so that you can't zoom out past the full extent of the largest layer in a map pack.  Is there a way to programmatically get that value so that when you change map packs it can automatically calculate that?
Also, is there a way to force the map object to limit the pan range so you can't pan way over past the edge of the world and then zoom into whitespace and get lost?
James
Outcomes
