Hello people,I'm sort of a new Flex API'er. I've been customizing the default editor for a couple days and need some fine tuning. Questions 1: How do I customize the default editor InfoWindow comment area? The boxes are too large where you provide your text/comments.Question 2: My application had a BorderContainer enclosing the editor and the legend. However, when you click to add a point with the editor tool in the "right" place, the InfoWindow will be partially covered by the BorderContainer. I realize that resizing the comment boxes in the InfoWindow will most likely alleviate this problem, but I'd like to know how to do it.Thanks for the help!!Here's my code:<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:s="library://ns.adobe.com/flex/spark"
xmlns:esri="http://www.esri.com/2008/ags"
initialize="application1_initializeHandler(event)"
pageTitle="DOE Sidewalk Inventory Comments">
This sample shows you how to use the editor component.
<fx:Style>
@namespace s "library://ns.adobe.com/flex/spark";
@namespace mx "library://ns.adobe.com/flex/mx";
@namespace esri "http://www.esri.com/2008/ags";
esri|InfoWindow
background-color: #FFFFFF;
border-thickness: 2;
</fx:Style>
<fx:Script>
<![CDATA[
import com.esri.ags.geometry.MapPoint;
import com.esri.ags.layers.TiledMapServiceLayer;
import mx.events.FlexEvent;
public function turnonbasemap():void
photo.visible = false;
basemap.visible = true;
public function turnonphoto():void
photo.visible = true;
basemap.visible = false;
protected function application1_initializeHandler(event:FlexEvent):void
myEditor.featureLayers = [ sidewalkcomments ];
</fx:Script>
<fx:Declarations>
<esri:GeometryService id="myGeometryService" url="http://webags/ArcGIS/rest/services/Geometry/GeometryServer"/>
</fx:Declarations>
<esri:Map id="myMap" left="0" right="0" top="0" bottom="4" wrapAround180="true">
<esri:extent>
<esri:Extent id="washco"
xmin="7565269.4485383" ymin="657281.31999349" xmax="7607044.62214942" ymax="696603.368604601">
<esri:SpatialReference wkid="2269"/>
</esri:Extent>
</esri:extent>
<esri:ArcGISTiledMapServiceLayer id="basemap" url="http://webags.co.washington.or.us/ArcGIS/rest/services/Washco_primary_basemap_SP/MapServer"/>
<esri:ArcGISTiledMapServiceLayer id="photo" url="http://webags/ArcGIS/rest/services/Washco_orthos2008_StatePlane/MapServer" visible="false"/>
<esri:ArcGISDynamicMapServiceLayer id="legendLayer" name="Sidewalk Inventory" url="http://webgis-vm/ArcGIS/rest/services/DOE/DOE_Sidewalk/MapServer"/>
<esri:FeatureLayer id="sidewalkcomments"
mode="snapshot"
outFields="
url="http://webags.co.washington.or.us/ArcGIS/rest/services/Planning/Web_Comments_Sidewalk/FeatureServer/0"/>
</esri:Map>
<s:Button right="40" top="31" width="94" height="31" label="Photo" fontWeight="bold" fontSize="16" click="turnonphoto()"/>
<s:Button right="134" top="31" width="106" height="31" label="Basemap" fontWeight="bold" fontSize="16"
click="turnonbasemap()"/>
<s:BorderContainer bottom="6" width="670" height="175" borderColor="#808080" borderWeight="2" fontWeight="bold"
cornerRadius="5" horizontalCenter="74">
<s:layout>
<s:HorizontalLayout paddingBottom="15" paddingTop="15" paddingLeft="15" paddingRight="15"/>
</s:layout>
<esri:Editor id="myEditor" bottom="4" width="200" height="120"
geometryService="{myGeometryService}" horizontalCenter="-204" map="{myMap}"
skinClass="com.esri.ags.skins.EditorSkin"/>
<esri:Legend id="myLegend" right="10" bottom="10" width="429" height="150" chromeColor="#CCCACA"
layers="{[ legendLayer ]}" map="{myMap}" respectCurrentMapScale="true"
skinClass="com.esri.ags.skins.LegendSkin"/>
<esri:Editor x="209" y="330" width="193" height="102"/>
</s:BorderContainer>
</s:Application>
